Isf front brake calipers
I read on another thread that the isf brake calipers would fit with the gsf rotors on the 3is does anyone have experience with this? It claims no brackets are needed nor the isf hubs any help would be much appreciated thank you!
All I know is Lexon sells a kit that uses GSF Calipers and 380mm rotors. I beleive no bracket needed, but not 100%. Their rear kit for GSF calipers requires their custom bracket.
Doesnt exactly answer your question sorry.
all depends you can get isf calipers with front gs350 fsport rotors and rear isf rotors that will need brackets or you can get a hub spacer up front with isf rotor no bracket i think im in the middle of changing to the isf calipers
Evilt78
08-17-13 07:08 AM
emikelee
35
03-14-11 09:24 AM
