Bass Amp Volume Knob
So I finally caved and got 2 12' subs with an enclosure with a BOSS 1500W amp. The amp comes with a remote volume ****, but i want it to look oem. I have the base model so there are 6 blanks where the HUD and mirror fold buttons usually go, its the same size as the interior trunk release. Im looking for the blanks that i can fabricate to make a dial built in to one of these. Or if these exist, the link to the part or part number.
Thanks
Thanks
Not a lot of space to work with there. Why not modify an existing blank?
Personally I mounted mine under the dash (right under that row of switches you mentioned) in the thin plastic tray under. Two tiny self tapping screws (supplied with the **** that came w/ the amp)
when i first got my bass ****, it was just doubleside taped under my steering wheel. i found that it looked stupid and that i actually used it quite often, so i spent a lot of time fitting my bass **** into the factory blank plate. couldn’t be happier, looks oem 😀.
How did you remove the blank plate?
removed the panel under the steering wheel. removed the panal to the left of that area (it's the were the door closes up against). reached in from behind and pushed the blanks out.
Pittsy (10-05-18)
FSportDRM
09-18-16 09:25 PM
