Starry night halo
Personally i would not waste money on that. That and someone tried opening up these headlights and apparently these are particularly difficult, if not impossible to open cause the glue and frame is extremely stiff. If that's true, you might damage something, or at least spend a lot more time than usual. Then you may have moisture problems once you button everything back up and if you do, there goes your LED chipset/drivers. And then you'll need a new $1,000 headlight.
I opened my DRL's and I know theyre completely different, but if the same tabs and adhesive are used in the headlight, it will be a difficult job. Especially considering the Headlight is a lot bigger than the DRL. Not to mention if you screw up, youre out a lot more than just DRL
SeanO
05-06-18 05:16 PM
