New Footrest
Old 11-28-19, 03:55 PM
evltwn
evltwn's Avatar
Originally Posted by athanato
Thanks, I ordered both off ebay in the US as they are cheaper than Canada *shocking*.
How did you install the parking break pedal, does the original rubber one clip off so you can clip on the metal one?
The parking brake pedal was tricky. I saw one member who cut out the center rubber **** and then drilled a hole into it. He then attached a nut and bolt to it. I tried this method and it didn't work for me.
I ended up cutting out the inner edges of the new pedal and used gorilla clue to attach it to the original rubber pedal, and this has held up well.
Old 11-28-19, 07:06 PM
athanato
athanato's Avatar
I figured I'd end up having to use my 30lb gorilla tape, will see first hand when I get it. thx
Old 11-29-19, 02:41 PM
evltwn
evltwn's Avatar
Here are some pics of my pedal.
athanato (11-29-19)
Old 12-31-19, 03:54 PM
athanato
athanato's Avatar
what are the measurements for the screws you used for the foot rest?
Old 12-31-19, 06:26 PM
flowrider
flowrider's Avatar
Received 1,924 Likes on 1,356 Posts
Great idea for the Dead Pedal
Lou
evltwn (01-16-21)
Old 01-01-20, 08:46 AM
Nguyenerr
Nguyenerr's Avatar
Looks great!
Old 01-01-20, 07:56 PM
athanato
athanato's Avatar
Is there a thread with that bolt on work around?, gorilla tape did not work out.
Old 01-02-20, 06:58 AM
evltwn
evltwn's Avatar
Don't use tape to attache it, try using super glue. That's what I did, and it's been fine. The bolt work around was in a member's build thread. I'm sorry, I don't remember who.
Old 01-02-20, 07:11 AM
evltwn
evltwn's Avatar
Lucky you, I was able to find the thread. Here ya go.
https://www.clublexus.com/forums/bui...ml#post9573574
athanato (01-02-20)
Old 01-02-20, 08:01 PM
athanato
athanato's Avatar
That would require a two part epoxy to hold well.
Old 01-02-20, 08:26 PM
evltwn
evltwn's Avatar
I only used super glue to attache the 2 pedals together. You can try the screw method if you like.
Old 08-15-20, 12:06 AM
athanato
athanato's Avatar
I ended up just gluing the dead foot rest with construction adhesive, it's going nowhere. For the parking break I removed the existing rubber cover and bolted on the f sport pedal and used a little of the construction adhesive to prevent it from twisting around.
Old 08-15-20, 12:56 AM
evltwn
evltwn's Avatar
Any pics of your pedals?
vraa
02-27-20 03:38 AM
xknowonex
SC- 1st Gen (1992-2000)
28
07-27-10 08:15 AM
Gojirra99
10-31-07 02:09 PM
audi2nr
46
09-10-07 09:52 PM
GFerg
03-04-06 12:24 AM
Quick Reply: New Footrest
