Humming Noise While Driving
Old 03-04-21, 02:30 PM
marcu725
marcu725's Avatar
Originally Posted by arentz07
If the only change between having the noise and not-having the noise was your tires, I'd say they are the culprit. When I put some BFGoodrich G-Force Comp-2 A/S on my IS, I immediately started having a humming sound afterward. I have heard reports of Michelin PS4S and PS A/S 3+ also having this issue.
Thanks for your response. The only change is new tires and an alignment. Does this tire hum ever go away or soni look for a new tire when I'm due?
Old 03-05-21, 06:56 AM
arentz07
drives cars
arentz07's Avatar
Received 3,805 Likes on 1,930 Posts
I don't think the hum will ever go away. It's just a fact of how the tires interact with the road and the air.
edit: Having said that, I think it'd be worth making sure everything is in-spec as far as alignment, tire pressures, etc.
Old 03-05-21, 08:33 AM
bgross88
bgross88's Avatar
hate to bring back an older thread but I just had a new set of Michelin Pilot Sport 4s mounted and balanced yesterday followed with an alignment. Now I get the same humming mentioned above from aboute 30-50mph. It does not get louder with speed. I will be going back to the shop tomorrow to get the alignment before/after printout.
BTW I have a 2014 IS350 AWF F Sport with ~75k miles
Had this happen with an older non-Lexus vehicle. Goodyear tires. Had 4 tires mounted balanced and it made a horrible humming noise at speed. Took it back..turns out they mounted 2 of the tires incorrectly(inside out/backwards--not sure how to word it)--that was causing the hum. They remounted them and it went away.
Old 03-05-21, 08:40 AM
marcu725
marcu725's Avatar
thats a good thing to check. im going back to the shop today to get a copy of the alignment data so I will have them check this.
Old 04-06-23, 07:29 AM
terryakhan
terryakhan's Avatar
Exactly the same noise on my 2019 ES 350
Dealer replaced 4 tires and the sound is way louder since the new tires are quieter.
Dealer examined my car and no fault found.
Will set an appointment to have a more experience tech with noise trouble shooting for a test drive.
Will report back.
lexuslover
08-19-23 09:19 AM
Plim89
Hybrid Technology
19
09-06-18 10:22 PM
sallydrive
03-05-12 08:18 AM
Evel
04-17-09 06:21 AM
chuckisc
02-25-03 06:01 AM
Quick Reply: Humming Noise While Driving
