looking for reverse camera 2014 is 250
Received 1,737 Likes
Where are you located? Maybe we can help you find one locally if we know where you are.
Ok...we may not be that much help for local.
Did you check the trunk lid to see if your car is pre-wired for a backup camera? Check the pics here to confirm if your vehicle is pre-wired: https://www.clublexus.com/forums/is-...ml#post9775196
If it is, then you need an OEM camera. If it's not, then there is a ton of aftermarket options.
Ok...since it's pre-wired the easiest thing to do is get an OEM camera.
For this upgrade you'll need 3 parts:
86790-53031 - Camera
82181-53040 - Wire Harness that connects the camera to the existing plug in trunk
76801-53090-XX. - Exterior License plate trim panel with hole cutout for the camera (XX is your paint code)
You will need to cut a hole in the metal trunk lid for the camera.
The thread I linked in Post #4 above has pics and tips in it.
Where to find the parts:
Camera:
https://www.mylparts.com/oem-parts/l...Y2LWdhcw%3D%3D
https://www.ebay.com/sch/i.html?_fro...53031&_sacat=0 (used cameras on ebay)
Harness:
https://www.mylparts.com/oem-parts/l...oom-8218153040
Trim:
https://www.mylparts.com/?p=catalog&...tr=76801-53090 (would need to know color to get the right part)
Since the harness and trim piece are not terribly expensive, you may just want to get them from the nearest dealer to you.
eBay is you best bet to get a good used camera at a fraction of the cost.
At least with the part numbers you can search whatever local part vendors are available to you.
Camera:
Harness:
Trim:
christ0efu
09-16-15 11:04 PM
