taller tires on stock rims
I have an AWD IS350 and i decided to replace the rear tires with 255/40r18 instead of 255/35r18. I really wanted taller tires to protect my rims because i live the NE and potholes are everywhere.
Once installed i got the "Check AWD System" message. I know they are about an inch taller than the fronts but i didnt think it would be that big of an issue other than the speedo being inaccurate.
Should i replace the front tires with 225/45r18? I know the speedo will be wrong but the tire heights will be the same again. Would i run into the CEL message again?
drives cars
I believe they have the same setup with taller sidewalls. Ideally you'd want the tire diameter F/R to be as close to identical as possible.
ShrinkDoc (01-27-19)
An inch in difference is really a lot for an AWD system...(Think of tire manufacturers recommending replacing all 4 tires if the tread difference is greater than 4/32"), and it may damage the system in a long run. If you don't mind the speedo inaccuracy...I would recommend replacing the front tires with a taller sidewall as well....(Pothole usually gets the front tires anyways. I popped 2 front tires in a year here at NYC...back tires are totally fine, then I ended up replacing all 4 because the tread life is bad for the original tires).
Once you change the front and the difference is .1 you will be fine, the current difference is aspect is the problem. I’m planing on doing the same and going with bigger side wall tires on my next set, I am RWD so I won’t have your problem.
my Previous 2017 STI AWD system like most other AWD system are very sensitive to tire size difference and it will effect function of the AWD system. My advice is not to drive until you get the new tire size on and make sure overall tire height is the same to avoid any damage to your AWD system
Paging @ShrinkDoc
- 255/45/18 (fronts
- 225/50/18 (rears)
drives cars
This might be obvious, but thought I would mention that I think you accidentally swapped the front and rear sizes, lol. 225-width is typically the size on the front, 255's in the rear.
Oops, yes, got them mixed up. But yes, the 255's are on the rear and 225's on the front.
BTW, OP, you cannot get a taller tire on either the front and rear w/o rubbing.
Tavares242
03-02-18 01:42 PM
