Installing GS-F/RC-F front lower control arm bushing?
#31
i just checked google maps your 15 min from Markham, go see this guy if you want he’s the independent master Toyota tech I saw last week..
https://www.kijiji.ca/v-other-auto-p...ationFlag=true
thats his ad his contact info is there. He would do the work right in front of you and surely charge you no more than 30 min labor, he was really good working on my car I got to sit beside him and watch everything
That's what I'm doing...waiting for the weather to get better.
Likely when I have the front up to put on the summer wheels I'll do it at the same time.
If you got jack stands, just use those.
With the car ramps once you loosen off the bushings the weight of the vehicle may cause the end of the control arm to move slightly.
It's not fall or nothing crazy like that, just might be a little hard to get the holes for the bolts lined up exactly...not the end of the world though, that's pretty easy to get around.
There's a couple shops in Richmond Hill near me if you need a recommendation.
#32
Received 1,737 Likes
Obviously he hasn't done one before...but he shouldn't be guessing if he hasn't.
If it was a Toyota, then he is correct for the vast majority (if not all) their vehicles.
#33
I just shared this Youtube video to the mechanic:
Will have to wait and hear back if he'll lower the labour rate. Man I sound like I'm being cheap for haggling on the labour $$$ lol
#34
The 3IS process is even easier than the ISF...the subframe is slightly different in that spot on the 3IS making it easier for the bushing to slide out.
Otherwise it's the same 4 bolts and 1 nut per bushing to remove.
#35
There’s another video of the install with the RR Racing bushings. It really isn’t that complicated ESPECIALLY if you have a lift. So 2.5 hours is pushing it.
#36
I shared a photo of the bushing location (underneath the car) and explained that I have an entire new bracket/bushing.
https://www.youtube.com/watch?v=RWa3EDMvQXE&t=47s
#38
Former Sponsor
#39
Former Sponsor
Also, I did not see a torque wrench involved in the re-tightening of the bolts
Jbreezie (04-02-19)
#40
Started as a good video, but he completely messed up the bushing lubrication. You do not lube the arm. There is absolutely no movement between the arm and center cylinder of the bushings. These parts are bolted tightly together when the nut is installed. The lube goes on the outside of the metal center cylinder of the bushing (where metal meets polyurethane).
#41
How does one torque the nut to 83 ft-lbs with the wheels on the ground? Is there enough space to work with?
Also, something weird. I found in another thread different torque specs for the large bolt and the bracket ....different from post 18. Which one is correct?
#42
I'd go to a car shop if you don't have jack stands. It is super easy to do it on a lift jack.
..... but I will never pay 350$ for that and not even 100$ ... call me cheap but 50$ is already expensive for a 15-minute job.
I would not get alignment right away if you do the above. Drive the car and if your call pulls to either side on a straight road then go for an alignment...
I did mine and didn't need an alignment but then again, your experience could be a different case.
#43
#44
I have jack stands, but my jack isn't low enough to get it in to raise the entire front of the car. If I use the hydraulic jack on the pinch weld, is there a place on the frame where I can put the jack stand?
#45
Its a 30 min job from start to finish. A lot of people quote high because they think they have to press the bushings, show the shop a picture, tell them there’s no pressing & your friend had it done in 30 min. Some shops charge a minimum but not hard to find a shop that would charge a half hour. Alignment is a good assurance but not necessary. I installed mine, went for an alignment and the shop told me I was in spec for everything and didn’t charge me. But again it’s a cheap assurance.
