Installing GS-F/RC-F front lower control arm bushing?
Old 01-15-21, 11:03 AM
  #91
Sasnuke
Sasnuke's Avatar
Received 1,737 Likes on 1,370 Posts
Originally Posted by lottadik
Does car need alignment after Even if bolt marks match up to the old ones?
No...technically you are not changing any alignment angles unless you are ordering the Caster offset versions of the bushings...most people order the 0 offset ones.
Although, if you haven't had an alignment in a couple years, it wouldn't be a bad idea...just in general.
lottadik (01-15-21)
Old 01-15-21, 11:05 AM
  #92
lottadik
lottadik's Avatar
Thanks, i assumed these affect alignment because of the eccentric holes. Why not use standard bolt holes then?
"gsf bushings on a 3rd gen gs rwd fyi"
Old 01-15-21, 11:30 AM
  #93
Sasnuke
Sasnuke's Avatar
"gsf bushings on a 3rd gen gs rew fyi"
I can only guess that the slotted holes allow for fitment on a wider variety of vehicles. The GSF/RCF bushings fit 3IS, 2IS, ISF, GS, RC, and probably more vehicles.
I'm sure if you force it in one direction or the other it could effect the alignment, but letting it sit naturally seems to be the easiest thing.
The following 3 users liked this post by Sasnuke:
andwutfu (03-18-21), kj07xk (01-17-21), lottadik (01-15-21)
tarponman
RC F (2015-present)
15
03-18-21 01:40 AM
bcorey
01-22-13 02:44 AM
baboya96
02-28-12 12:09 PM
MU521
Suspension and Brakes
12-31-10 08:43 AM
SLowEvo
12
12-12-10 12:24 PM
Quick Reply: Installing GS-F/RC-F front lower control arm bushing?
