Wheel Fitment for Work D9R
Hey everyone. Would the following specs fit on the IS? Don't want rubbing on anything, all stock suspension(sorry guys, air suspension is too expensive to install)
19x9.5 +23 225 Front
19x10.5 +30 245 Rear
Came off an ISF previously. Would I need any spacers or hub centric rings as well?
Received 1,735 Likes
Unfortunately the offsets are too low and the tires are way too small...they must be serious stretched!
If I were to get a new set of wheels either the M8R or D9R would a +38 offset each side suffice using the same wheel sizes and widths but putting on the right tires.
If you wanted a 10.5 in the rear, you'd need something around a +45 offset...even a +48 would be better.
The 9.5 on the front is really wide for these cars. With the right size tire it will likely rub on the steering knuckle upright.
You could drop down to a 9 or 8.5.
I was thinking 18x9 +38 for the front and 18x10 +38/+45 for the rear. Overall plan is to have air suspension installed in a year or two with everything all setup for barely an issues. Sorry, wheels are a new thing for me so still learning.
The rear you want to aim for the +45 since you want to install air later on.
If you weren't going to get air then you could have gone closer to the +38.
