Installed RCF / GSF bushings..
48076-24010
At least those are on my order.
48076-24010
The following 3 users liked this post by sunamer:
Did you already buy the parts? It takes 30 minutes to do so you should be paying 30 min of labor OR 1 hour if they charge a minimum. Call a reputable shop in your area, explain you bought the part, Text or email them a pic of the part so they can understand what it is. Tell them the bushing is already in the new bracket and it’s a few easy to reach bolts to swap. Tell them you know it takes 30 minutes to swap and ask how much they would charge to do it.
It should be around $100 since it should easily be done within an hour. I would guess a shop would probably charge that just to make something on it since it is so quick and easy.
Someone quoting $700 probably doesn't realize the simplicity of the tasks and figures they will have to dismantle other suspension components, press bushings, etc. It's really simple, 3 bolts on each side. Pull them off, install the new ones, load the suspension and torque the bolts.
Yeah that's what they've been charging. I went to 3 different mechanics and they all said it would be 4 hours. Two I showed a picture, but I'll have to wait until the parts come in (hopefully next week) and try again.
It's pretty silly. The one shop I even showed them while it was up on the lift and they were still humming and hawing -- dude look, it's three bolts! My mechanic was wary too, then when he did them I said "Easy, right?" and he agreed. He had the one front spring on and the LCAs done in about the time it takes to do the spring alone, plus he took pics.
This has been previously posted somewhere. I showed my mechanic this video after he quoted 4 hours and he charged me $100 for the job. Its like 30-45 min.
https://youtu.be/RWa3EDMvQXE
Now just have to wait for the part to be here.
Question, please.
Just purchased my GS/RC-F front LCA bushings from mega zip.
I had to kind of last second buy some tires last week so next day put in a order for the bushings. Wanted to do all at the same time before alignment, but oh well.
Now I'm waiting to do alignment until they get here and installed. Est. Arrival 09/23-09/30. Should I wait to do alignment? I drive about 80miles a day.
Is alignment necessary after install of the bushings? Don't want to go too long on new tires with no alignment....and who knows how long I'll actually wait these are going to ship from Japan.
Thanks
Thanks
Question, please.
Thanks
Thanks
an alignment never hurts and it’s best to play it safe so while you technically might not need one you should probably just drop the few extra $$$ and get it done.
I'm definitely gonna get it done just whether I wait until they're here (and go on new tires w/out alignment until then). Or, get the alignment now and not after the bushings install.
Anyone else find they did not need alignment after bushing install?
If you get it done by a good mechanic, you don't really need an alignment or to torque the bolts back. I made sure everything lined back up to the stock LCA bushings and lined the bolts back to their original positions, air tools makes this really easy on a lift.
Did noticed a better drive and stability after but not significant but car feels better though.
Probably doing myself most likely.
I don't think I'll need an alignment. It's somewhat related but not really.
Not sure what you meant with torque. When I was working in a shop we used air tools but always did final torque to spec by hand.
