Can steering be tightened?
0 degree Caster
if you’re lowered you get one with a certain degree of caster, experts will have to chime in on which ones to buy if you’re lowered.
I bought and installed those part #’s on my car, stock suspension.
Looks like an easy install..
1. Would I need an alignment or alignment check after i do the install?
2. Does anyone know if Lexus fixed the excessive inner tire wear on the 2018 model?
Thanks guys this is all really helpful information
super easy install, 3 or 4 bolts each side. With a lift it’s a 25-30 min job from start to finish. No alignment required but doesn’t hurt to do alignment (you might be out of spec and not realize it) I did not get an alignment. I thought some suspension components were tweaked on 2017 or 2018 models not sure what specifically.
48075-24010 - Bracket Sub-Assy, Lwr Arm, No,1
https://www.megazip.net/zapchasti-dl...o-1-4807524010
48076-24010 - Bracket Sub-Assy, Lwr Arm, No,2
https://www.megazip.net/zapchasti-dl...o-2-4807624010
