Engine oil, does it matter?
Here's some good reading from Blackstone where their lead tech gathered long term data from different engines using a variety of oil brands from cheap to really expensive. TL;dr? Brands don't matter. But engine, time used, when changed matters.
https://jalopnik.com/why-expensive-o...ney-1797241527
Yeah. As long as it meets spec and maintains viscosity and shear resistance at temp, and has good detergent properties, I see no reason not to use it. Blackstone would tell you if something is wrong. Conversely, there's also little reason to not go with Castrol at a few more bucks a bottle, but a few bucks can pay for your oil filter.
Do they have Amazon in germany? how does that work over there?
Apparently, you can get this same oil branded as Supertech by Walmart for $15. https://www.walmart.com/ip/Super-Tec...arts/254038905
And Blackstone seems to say it's good as well.
https://www.clubfrontier.org/forums/...vealed-349323/
There's no direct evidence it's the same oil but everyone online seems to think it is.
drives cars
https://www.lexus.com/pdf/service/MY...ices-Guide.pdf
