High Beam hotspot after adjusting headlight beam
Hey everyone,
Can someone advise if this is normal.
I tried to adjust my driverside lowbeam up just slightly and it seemed to work fine however, when turning on high beams, the driver-side now has a pretty large hot spot. The passenger side doesn't have this issue. I'm not sure if this is by design, but i'm pretty sure both sides are supposed to be pretty much identical.
In the video you'll notice the camera re-focus and you can definitely tell the hotspot when the high beams are on.
I followed instructions on how to adjust the headlight from another video but after closer look, i don't think it's 100% correct. i think i'm adjusting something on the high beam perhaps?
can someone advise if this is normal?
(Sorry the video is flipped upside down for some reason).
are we talking about the headlights of a Ford van? or a chicken truck? garbage truck? exactly what year make model are we talking here.
If you have an older style 3IS, then AFAIK the low and high beams adjust as a single unit, as does most cars. I don't know about the newer models. Either way headlights (typically) should be identcial left to right). your video displays weird for me, can't really tell what's going on. a photo would be better of both patterns. (and easier quite frankly)
high beam on
low beam
from google:
The top of the low beam shining on the wall should be at or slightly below the height of the center of the headlight lens for most vehicles. You should expect the light pattern to be higher on the right side (passenger side) to illuminate road signs and lower on the driver's side to prevent blinding other drivers.
from google:
I"m just asking because I have a bad habit of trying to be a perfectionist and I just like to see things evenly haha. I'd rather have my driver side match with the passenger side, that's all. Either way, I'll just try to reverse the screw direction on the driver side headlight to see if it'll fix the hot spot issue. I just wanted to know if this "hot spot" was designed this way or not since I didn't check prior to making the adjustments on my headlights.
