Anyway to stop the beeps on the temp controls?
Its a little thing.. but, hate that high pitched beep every time I change the temp in this car. Anyway to remove that?
I don’t believe there is. I had the carista plugged into my car I disabled the chime when no belts are on. I don’t remember seeing an option to mute those beeps for the hvac. However, there was a decent list of things to change in the HVAC menu. Might be your best and cheapest option to get carista off amazon. It’s only $25 and you can easily return it if it doesn’t work.
Found this while researching. My ‘22 IS 350 beeps but I had a loaner NX 300 which did not. Different physical controls but still—gives me hope of being able to disable it!
Any new discoveries ??
Greetings from Spain. I had the same issue with the annoying beep whenever I changed the temp, but luckily I found a way to disable it!! If you want to know, just tell me.
drives cars
Use the samlalon method: in the AC module, press the buttons "Auto" and "Off" at the same time until you hear a beep (2-3 seconds) and you will see the word "OFF" in the little screen of the AC temp. This will be the last beep you will hear. At least it works in my IS: December 2020. You're welcome! ;-)
mattssi
11-08-06 05:42 PM
