Transmission clunk from park to other gears
Hi. Whenever I shift from my park to reverse or drive even on a flat service, my entire car ( 2015 is250 53,000 miles) clunks even with the e brake on. It is very noticeable going from p to r. It seems like I really need to press down really hard on the brake pedal to either stop or lessen the clunk. I also shift each gear slowly of doing it fast and waiting for it to lock in before going to the next gear should I be just park pulling straight down to D instead of p to r to n to d. Which is the correct way? Thanks .
my 2015 350 AWD, same tranny as yours does same thing, especially when cold. You really hear/feel it going into reverse. As long as you wait a second before gassing it after going into gear you’re fine. I noticed if cars warm, from driving recently it’s a lot let noticeable.
I've never experienced a "clunk", but I have had the transmission be a little more jerky if I don't give the revs a good 5-7 seconds to drop before I put it into gear (while holding the brake, obviously).
Their really bulletproof transmissions, Lexus has been using it for well over 10 years, most likely your over thinking it or maybe it’s just how your shifting/pressing brake? I’d be absolutely blown away if the 6 speed tranny we have would have any sort of mechanical issues at 53k miles. Have you done a tranny drain n refill yet? And you still have powertrain warranty so I wouldn’t even sweat it, drive it, if it gets worse bring it in to Lexus
This would apply to literally any car ever. You shouldn't press that gas pedal until the gear has engaged.
you replied with a confused emoji than proceeded to tell me exactly the same thing I said that you shouldn’t hit the gas right away after putting it into gear....
My point was that I have never driven a car where, if I press the gas before the gear engages, it's smooth. There's always a jerk if I do that. It's not exclusive to the IS.
savala88
10-09-10 05:30 AM
