2014 IS250 Radio Question P10433 swap to another model
#31
i found it on ebay ( about 1,100 american dollar) ...
#33
I tried a 2017 radio head (facelift) unit with Nav and swapped it into mine which is 2014 with Nav & ML but it doesn’t fully work. The system seems to adjust the resolution to the smaller screen for the maps but once it is in the main menu it doesn’t show what you’re able to select.
Saying it here so people don’t need to try the facelift radio as it doesn’t fully work.
#34
#35
As you mentioned in the other thread the unit you have is P10443.
From the list you provided above of ID numbers, for sure you can't use P10998.
Online information indicates that P10998 is for the Mark Levinson (15 speaker) system, to which you have the Standard Audio (8 speaker) system.
Radios P11010 is a US spec radio for Hawaii, Guam, and Puerto Rico.
You may run into a language issue and/or Map issue where you may need a new micro SD card that is for your region.
The radio should plug in and function properly otherwise.
P10762 is an RCF radio for a 10 speaker system.
Another member swapped an IS P10435 (Canadian spec standard audio without Navigation radio) for the P10762 and the radio did work.
They did need to get a new micro SD Map card...along with a GPS antenna.
You may run into a language issue though.
do you know if I could swap a p11010 for a p11012? I would not care if I lose my maps. I just want a radio. I do not want to spend almost 2k on p11010
