Brown/Discoloured Tires?
Old 08-13-19, 06:19 PM
BondJames
BondJames's Avatar
Tire brush is a must. Since your using one I would get a dedicated tire and wheel cleaner. I use Eagle1 but, not all the time. If you don’t get them clean your tire dressing is not going to absorb that well and won’t last long. You will be amazed at how much black residue the Eagle1 will remove.
I saw detailing video on tires and wheels by Mike Phillips of AutoGeek. He says tires are manufactured to “chalk” rubber to help with the rubber from drying out.
Try cleaning with Eagle1 agitate with your tire brush and they should clean up good. Personally I am not a fan of wet look tire and use Black Fire tire gel. It gives a natural sheen with deepest black I have ever achieved. Last for 2 to 4 weeks and doesn’t sling off and if you desire more sheen apply another application. When I use Eagle1 I always have to apply 2 coats since, it cleans the tires so well.
Old 08-13-19, 06:58 PM
SpicklePie
SpicklePie's Avatar
Thank you for your response and suggestions, I really appreciate it! Since I'm located in Toronto, Canada, I'm not sure if I would be able to purchase Eagle One (I've never seen it around before). But, I'll do some research and see if it's available in Canada. I'll also check out the Black Fire tire gel. Thanks again!
Old 08-13-19, 07:59 PM
ex00
ex00's Avatar
All you need to do is take a soft bristle brush meant for tires and wheels like the green one sold by Chemical Guys and some diluted Super Clean. Spray around the tire and let it sit for no more than 30 seconds. Then start scrubbing away keeping the brush wet. Rinse and repeat as needed. It takes it away like butter and I have been doing this at least once a month to put on VRP which works wonders for me.
Basically dirt just sticks onto the rubber and stays on no matter how you wash it with just soap and water.
Old 08-16-19, 08:19 AM
E46CT
E46CT's Avatar
Received 2,185 Likes on 1,639 Posts
that's just sort of salty road i-never-dress-my-tire stuff. just use a high quality tire dressing such as this
it's a bit pricey but i've had mine for three years now and barely used 1/3rd of it. so the value is outstanding
vs buying a $9 can at the auto parts store every month.
Old 08-16-19, 02:03 PM
enkrypt3d
enkrypt3d's Avatar
Or we can try this:
Old 08-17-19, 10:21 AM
tofuprod
tofuprod's Avatar
Meguiars Hyper Dressing, you can dilute it to your liking - water based, works perfect. You're welcome.
ilen
RC F (2015-present)
20
01-20-22 02:37 AM
LexiRX
01-14-15 01:03 PM
GC09GS
03-17-11 10:26 PM
njmurvin
09-19-08 11:03 AM
Bahadur
Wheels, Tires & Brakes Forum
01-21-04 11:04 PM
Quick Reply: Brown/Discoloured Tires?
