opinons needed on service history
Old 08-20-19 | 07:27 PM
Snis300's Avatar
Snis300
Default opinons needed on service history
I am about to make a purchase on this is350fsport and pulled up this service history. Should I be concerned with the water intrusion in the rear fender and the current shock leak that was declined?
SERVICE HISTORY
SERVICE HISTORY FOR: 2014 IS350
VIN: JTHBE1D29E5008876
Filter History By YearAllAll 2019 2018 2017 2016 2015 2014
55184 MILES
DATE: 08/09/2019
REPAIR# 0340219
REPORTED BY:
SERVICE: USED CAR DETAIL
DESCRIPTION: USED CAR DETAIL ~|~PREOWNED VEHICLE DETAIL ~|~ ~|~COMPLETED PREOWNED VEHICLE DETAIL INTERIOR CORRECTION
55184 MILES
DATE: 08/07/2019
REPAIR# 0339976
REPORTED BY:
SERVICE: UCI
DESCRIPTION: UCI ~|~USED VEHICLE INSPECTION ~|~ ~|~PERFORMED USED VEHICLE INSPECTION CHANGED OIL AND FILTER REPLACED LOCKING LUG NUTS
SERVICE: USED VEHICLE DECLINE
DESCRIPTION: USED VEHICLE DECLINE ~|~RIGHT REAR SHOCK IS LEAKING ~|~QUOTE 600.00 TO REPLACE ~|~DECLINED REPLACEMENT AT THIS TIME
50140 MILES
DATE: 03/02/2019
REPAIR# 6336833
REPORTED BY:
SERVICE:
DESCRIPTION: OUR PIT CREW INSPIRED APPROACH HELPS YOU GET IN OUT QUICKLY FOR BASIC ~|~ ~|~NO CAUSE SPECIFIED IN ROOUR PIT CREW INSPIRED APPROACH HELPS YOU GET IN OUT QUICKLY FOR BASIC MAINTENANCE, AT THE RIGHT PR
SERVICE: CUSTOMER REQUESTS TOYOTA OIL AND FILTER SERVICE
DESCRIPTION: CUSTOMER REQUESTS TOYOTA OIL AND FILTER SERVICE ~|~$34.95 COUPON ~|~
SERVICE: PERFORM COMPLIMENTARY MULTI POINT INSPECTION
DESCRIPTION: PERFORM COMPLIMENTARY MULTI POINT INSPECTION ~|~ ~|~NO CAUSE SPECIFIED IN RO
45224 MILES
DATE: 09/22/2018
REPAIR# 6322771
REPORTED BY:
DESCRIPTION: CUSTOMER REQUESTS TOYOTA OIL AND FILTER SERVICE ~|~ ~|~NO CAUSE SPECIFIED IN RO
39671 MILES
DATE: 03/17/2018
REPAIR# 0990971
REPORTED BY: Lexus of Knoxville
SERVICE: 10000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 10000 MILE SERVICE NON WARRANTY-NON OEM ~|~CUSTOMER REQUESTS 40000 MILE SERVICE ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE 3456 ~|~SYNTHETIC MOTOR OIL AND FILTRE CHANGE BALANCE ROAD WHEEL/TIRE ASSEMBLIES CHECK ANDE CORRECT ALL UNDERHOOSHOW LESS
SERVICE: OTHERS
DESCRIPTION: OTHERS ~|~FRONT BRAKE PADS WORH SUFFICENTLY TO WARRANT REPLACEMENT FRONT ROTORS TOO DEEPLY SCARRED TO SAFELY MACHINE SMOOTH ~|~REPLACE FRONT DISC BRAKE PADS AND ROTORS CLEAN AND LUBRICATE ALL RELATED COMPONENTS AS REQUIRED ROAD TEST
SERVICE: STEERING WHL/MAIN SHAFT
DESCRIPTION: STEERING WHL/MAIN SHAFT ~|~CUSTOMER STATES:"POP" FROM FRONT WHEN FIRST TURNING STEERING WHEEL INTIAL START UP ~|~INSPECTED AST CUSTOMER'S REQUEST NO REPAIRS NECESSARY
34431 MILES
DATE: 09/16/2017
REPAIR# 6291303
REPORTED BY:
SERVICE:
DESCRIPTION: LOF 27 PT CHECK LUBE OIL AND FILTER CHANGE ( ) CHA NGE ENGINE OIL AND FILTER ( ) ~|~ ~|~NO CAUSE SPECIFIED IN ROLOF 27 PT CHECK LUBE OIL AND FILTER CHANGE ( ) CHA NGE ENGINE OIL AND FILTER ( ) INSPECT AIR FILTE
SERVICE: 03TOZ
DESCRIPTION: 03TOZ ~|~ ~|~NO CAUSE SPECIFIED IN RO
SERVICE: SERVICE RECOMMENDED TODAY HAVE NOT BEEN COMPLETED
DESCRIPTION: SERVICE RECOMMENDED TODAY HAVE NOT BEEN COMPLETED ~|~ADVISED CUSTOMER LEFT FRONT BRAKES WEARING PREMATU RELY COMPARED TO RIGHT SIDE. CUSTOMER WILL TAKE T O LEXUS TO CHECK FOR POSSIBLE WARARNTY REPAIR ~|~
33593 MILES
DATE: 08/30/2017
REPAIR# 4603727
REPORTED BY: Lexus of Kingsport
SERVICE: COMPLETED MULTI POINT INSPECTION
DESCRIPTION: COMPLETED MULTI POINT INSPECTION ~|~ ~|~NO CAUSE SPECIFIED IN RO ~|~COMPLETED MULTIPOINT INSPECTION, NO CONCERNS FOUND AT THIS TIME
SERVICE: CUSTOMER STATES
DESCRIPTION: CUSTOMER STATES ~|~TOW IN - CUSTOMER STATES WONT START ~|~WEAK CELL IN BATTERY TEST CODE AOL2-60ED3-X2W3J WEAK CELL, AOL2-60ED3-X2W3J ~|~REPLACED BATTERY
28949 MILES
DATE: 05/13/2017
REPAIR# 0974024
SERVICE: *BATTERY SERVICE
DESCRIPTION: *BATTERY SERVICE ~|~CUSTOMER WOULD LIKE THE BATTERY TESTED IT HAS BEEN DEAD TWO TIMES, WAS LEAVING FOR FOB IN VEHICLE,STOPPED AND IT HAS NOT BEEN A ISSUE ~|~BATTERY TESTS GOOD, NO DRAW ~|~NO FAILURES FOUND, NO REPAIRS NECESSARY
SERVICE: *FLUSH BRAKE SYSTEM
DESCRIPTION: *FLUSH BRAKE SYSTEM ~|~CUSTOMER REQUESTS BRAKE SYSTEM FLUSH ~|~AS PART OF THE SERVICE ~|~PERFORMED BRAKE SYSTEM FLUSH
SERVICE: 30000 MILE SERVICE NON WARRANTY
DESCRIPTION: 30000 MILE SERVICE NON WARRANTY ~|~CUSTOMER REQUESTS 30000 MILE SERVICE REPLACE 2 KEY BATTERIES ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE 3180 ~|~REPLACE ENGINE OIL AND FILTER REPLACED TIRES INSPECT AND CORRECT FLUID LEVELS INSPECT EN... READ MORE
SERVICE: 4-WHEEL ALIGNMENT
DESCRIPTION: 4-WHEEL ALIGNMENT ~|~CUSTOMER REQUESTS 4-WHEEL ALIGNMENT. ~|~MAINTENANCE. ~|~COMPLETED 4-WHEEL ALIGNMENT PER MANUFACTURER'S SPECS.
SERVICE: GLM CAMPAIGN
DESCRIPTION: GLM CAMPAIGN ~|~COMPLETE GLM CAMPAIGN FOR INSPECTION OF THE INNER PORTION OF THE REAR FENDER ARCH FOR POSSIBLE WATER INTRUSION. ~|~VEHICLE REQUIRES INSPECTION OF BOTH FENDER ARCHES TO VERIFY FOR POSSIBLE WATER INTRUSION ~|~INSPECTED BOTH RESHOW LESS
SERVICE: TIRES
DESCRIPTION: TIRES ~|~REPLACE 4 TIRES ~|~REQUESTED ~|~COMPLETED
24928 MILES
DATE: 01/14/2017
REPAIR# 6270753
REPORTED BY:
SERVICE: PERFORM BASIC OIL CHANGE
DESCRIPTION: PERFORM BASIC OIL CHANGE ~|~ ~|~NO CAUSE SPECIFIED IN RO
21232 MILES
DATE: 09/07/2016
REPAIR# 0960070
SERVICE: CAR WASH
DESCRIPTION: CAR WASH ~|~LEXUS OF KNOXVILLE PREFERRED GUEST COURTESY WASH ~|~ ~|~INCLUDES EXTERIOR WASH, CLEAN TIRES AND WHEELS, APPLY TIRE DRESSING, VACUUM FLOOR MATS AND SURROUNDING CARPET, GENERAL DASH AND CONSOLE WIPE DOWN, AND CLEAN WINDOWS. COMPLE... READ MORE
19641 MILES
DATE: 07/16/2016
REPAIR# 6255253
REPORTED BY:
DESCRIPTION: PERFORM BASIC OIL CHANGE ~|~ ~|~NO CAUSE SPECIFIED IN RO ~|~COMPLETE
DESCRIPTION: PERFORM COMPLIMENTARY MULTI POINT INSPECTION ~|~ ~|~NO CAUSE SPECIFIED IN RO ~|~COMPLETE
14558 MILES
DATE: 01/02/2016
REPAIR# 6239622
REPORTED BY:
SERVICE: LUBE OIL AND FILTER SPECIAL
DESCRIPTION: LUBE OIL AND FILTER SPECIAL ~|~LUBE OIL AND FILTER SPECIAL ~|~
12826 MILES
DATE: 10/31/2015
REPAIR# 0105739
SERVICE: BATTERY
DESCRIPTION: BATTERY ~|~CHECK BATTERY/CHARGING SYSTEM - HAD TO BOOST ~|~WEAK CELL
SERVICE: BATTERY COMB: BATTERY
DESCRIPTION:
9536 MILES
DATE: 06/26/2015
REPAIR# 0103275
SERVICE: 10,000 MILE FULL SERVICE
DESCRIPTION: 10,000 MILE FULL SERVICE ~|~10,000 MILE FULL SERVICE ~|~10K
4989 MILES
DATE: 12/15/2014
REPAIR# 0099757
SERVICE: 5,000 MILE LIGHT SERVICE
DESCRIPTION: 5,000 MILE LIGHT SERVICE ~|~5,000 MILE LIGHT SERVICE ~|~5K
6 MILES
DATE: 03/12/2014
REPAIR# 0904394
SERVICE: ACCESSORY
DESCRIPTION: ACCESSORY ~|~INSTALL ALL WEATHER FLOOR LINERS ~|~
SERVICE: PAINT PROTECTION
DESCRIPTION: PAINT PROTECTION ~|~INSTALL PAINT PROTECTION FILM ~|~ ~|~INSTALLED THE PAINT PROTECTION FILM HR
SERVICE: WINDOW TINT
DESCRIPTION: WINDOW TINT ~|~INSTALL WINDOW TINT COMPLETE @ 35% & AIR 80 ON WINDSHIELD ~|~TCT PO#154093 ~|~INSTALLED WINDOW TINT
6 MILES
DATE: 01/15/2014
REPAIR# 0901611
SERVICE: ACCESSORY
DESCRIPTION: ACCESSORY ~|~SHADOW MARK 274306 DS ~|~
SERVICE: PACKAGE A
DESCRIPTION: PACKAGE A ~|~PKGA DOOR EDGE GUARD (PPF) PINSTRIPE WITH LOGO NTERIOR PROTECTION PACKAGE LICENSE PLATE BRACKET (PPF) IN DOOR CUPS ~|~PERSONALIZATION ~|~COMPLETED PKG A
17 MILES
DATE: 01/14/2014
REPAIR# 0901247
SERVICE: PRE-DELIVERY INSPECT
DESCRIPTION: PRE-DELIVERY INSPECT ~
Old 08-20-19 | 07:58 PM
Perhaps the rear shock was replaced somewhere else?
Old 08-20-19 | 08:04 PM
Snis300's Avatar
Snis300
what does the water intrusion mean in the rear fender?
Old 08-21-19 | 04:28 PM
itsx's Avatar
itsx
There was a TSB where they needed to reseal some seams. IIRC it's just rust prevention.
https://www.clublexus.com/forums/is-...corrosion.html
As far as everything else, I usually do my own work on my car, or can get it done at my Indy tech for a better rate than the dealership. Plus I've got a good relationship with them.
If the dealership told me that my right rear shock was leaking and it's labor/parts weren't covered by warranty, I'd just decline service and do it myself or at a friends house etc.
Front brakes can be done for about $300 or so at home. This includes pads, rotors, and brake fluid. Obviously different pad + rotor combinations will cost more/less.
i think the Battery on the 2014 had issues, and other forum members had the battery issue resolved by having the ecu replaced through warranty. Not too sure since I have a 2014 and don't have any issues. I think I still have the original battery and I'm at 86k.
Old 08-21-19 | 04:31 PM
Snis300's Avatar
Snis300
So you think this isn't a deal breaker?
Old 08-21-19 | 04:49 PM
itsx's Avatar
itsx
Not for me. It's just a recall for it.
It's at 55k miles, I'd check all the brakes, check tires for toe wear, get an alignment possibly. Wouldn't hurt to do a brake fluid flush
Nothing major I can think of. I did my sparkplugs and coolant at 75k miles.
I do my oil changes at 5k intervals, so every 5k miles
Snis300
08-20-19 09:16 PM
xxmariolxx
01-05-19 01:45 PM
salesguy
10-15-16 01:40 AM
my06GS300
01-30-13 05:53 PM
460LSinTN
Maintenance
03-17-12 11:17 PM
