Driver door buzzing with audio - need a fix
hey guys,
this driver door buzzing while playing music is really wearing me out and making the car so unenjoyable to drive. the issue was fixed for a while after the dealer 'reseated' the panel..but after the summer heat and expansion and contraction, im back to square one. i know others have had a similar issue and ive tried those fixes. just curious if anyone else did anything other than adding felt to the window switch.
thanks
thanks
hey guys,
thanks
thanks
I feel like i need some extra padding/insulation behind the door and that will solve the issue...I don't want to use dynamat or any of those sound deadening materials because I think they smell pretty bad...Im wondering if I could use some acoustic foam..but i know you have to be careful what kind of material you put inside the door due to moisture retention...any thoughts on that?
I just replaced the vapor barrier, I think that is the part that is buzzing. I wasn’t able to reseat it without replacing it so we will see what happens.
Remove the driver window switches panel and wrap electrical tape around the switch box. That will fix it.
These pictures are from a GS, but it's the same issue. You can see how the switch box fits into the trim panel with some plastic tabs. It fits loose and allows it to vibrate.
https://www.clublexus.com/forums/gs-...el-rattle.html
Maybe there is more to your issue. But the sound I am talking about is surprisingly loud and can be heard over the radio at any volume level. After reading up on it, apparently it is pretty common in the IS and GS. After wrapping mine the sound completely went away. It would be worth the 2 minutes it takes to pop it off tape it up and see.
thanks, i will definitely give it a shot if the problem comes back! can you post a pic if you have a chance of exactly what you taped up? I taped mine in the past but it had no effect..
Be careful with touching the vapor barriers. I recently learned that modern cars side airbag systems are dependent on the vapor barrier as the system relies on pressure waves to determine exact deployment. Not sure the particulars of our cars, but it's probably worth being careful with it.
Henry43
04-13-19 10:31 AM
