Anyone run 17s for winters on FSport?
Old 09-26-19 | 11:13 AM
Sasnuke's Avatar
Sasnuke
Originally Posted by evchao
It doesn't beep right? I might just do that. Save myself 300$ lol
The light doesn't come on until 20 minutes of driving...so if i make a short trip, no light.
Once the light is on, it may start blinking too...but no beeping.
FYI...20 minutes is the threshold for when the TPMS ECU gives up trying to find the sensors and throws on the light.
Old 09-26-19 | 11:55 AM
kj07xk's Avatar
kj07xk
Since I'd find that annoying and distracting on a long drive (periodically take 2.5 hour trips), I bought my winter set with the TPMS installed.
Small price for my sanity (and keeps the wife from nagging (about that anyway) ).
Old 09-26-19 | 10:49 PM
pgaknot's Avatar
pgaknot
I also run 17's for the winter all squared up
Blizzak LM001 is a fantastic tire with the AWD
Install 3 or 4 mm shim if looking for a little clearance from front calipers
Old 09-27-19 | 04:24 PM
evident's Avatar
evident
yes, i run 17x8 enkei pf01s
Old 09-27-19 | 09:04 PM
athanato's Avatar
athanato
Originally Posted by GNS
I'm not paying $300 for that crap. I'll put some black tape over the light or something, as long as the tape can be easily removed after I switch back to summer wheels.
They are only $35 USD each on Amazon. I had zero issues with Denso (winter set) and Orange on my 2010 IS, I replaced the stock ones with Denso's in fact as one of the stock was failing and the stealership refused to replace it under warranty.
Old 09-27-19 | 09:11 PM
athanato's Avatar
athanato
I will be using my old Lexus stock 2010 IS250 225/40R17 (front) / 245/45R17 (rear) set on my 2018 IS300AWD, I test fitted them today at the shop and the clearance was there with my old Bridgestone Blizzaks on them.
I assume the 2018 IS300AWD uses the same calipers as the 350?
Old 09-28-19 | 07:34 AM
Sasnuke's Avatar
Sasnuke
Yes to the calipers.
athanato (09-28-19)
Old 11-01-21 | 11:54 AM
nitroracer's Avatar
nitroracer
[QUOTE=kj07xk;10620739]225/45R-17 Michelin X-Ice XI3 ($143.22 US each)
Talk about inflation! Their updated X-Ice now cost $205 each for the same size.
kj07xk (11-01-21)
Old 10-07-24 | 02:39 PM
Jep32's Avatar
Jep32
4th Gear
Can I run 17” x 7” off a 2021 NX300 on my ‘23 FSport? Offset 35mm, bolt pattern 114.3 mm
997c2
10-03-18 09:49 AM
ricam78
01-11-17 09:45 PM
doughster
RX - 3rd Gen (2010-2015)
05-30-15 05:45 PM
bshaw777
07-28-13 11:12 AM
Phresh2010
03-19-10 10:02 PM
