30k Service Price Outrageous
#31
It's actually very competitive to nearby dealers lol. We are very high volume so there's a lot of overhead costs to cover too.
#32
omg that’s so high my heads spinning. I’m in Ottawa, everything here is expensive as heck and dealers only 125. Even in Toronto i think dealers only 140ish. I can’t imagine, as a customer looking at a bill and seeing I’m paying almost $200 after tax per hour for Lexus to work on my car.
#33
So I was able to get a breakdown and more info. My dealer also include "replace rear differential oil" which is approx a $200 service. This, even though the manual says "inspect rear diff oil." I'm wondering if this is how they boost the price or if 90% of the time it's needed so they just include it legitimately. Looking at all of the service intervals, it seems that it's always "inspect oil" and it never says replace, so I guess that means you just replace it when it's needed.
Since it's a package there is an overall discount applied but if you remove items I guess that removes the discount as well.
Rough prices I was given (I guess there isn't really a price list, he'd have to type each one in to the computer to get a price so I was happy with ball parks).
Oil change: $190
Brake Fluid $180
Engine Air & Cabin filters: $100
Rear Diff $200
So there you go, that's how you get to $699.
Oil change: $190
Brake Fluid $180
Rear Diff $200
Jazzrock (01-16-20)
#35
Oil change: $190
Brake Fluid $180
Rear Diff $200
Oil change: $190
Brake Fluid $180
Rear Diff $200
My Lexus dealer charged me $37 for that when I did it on my 2015 350....It’s literally faster and easier than an oil change. That’s nothing short of robbery. Absolutely disgusting.
#36
Oil change: $190
Brake Fluid $180
Rear Diff $200
Oil change: $190
Brake Fluid $180
Rear Diff $200
#37
Lol you’re not wrong. It takes like 30 minutes max to do it. Unscrew drain plug, drain, screw drain plug back in, unscrew fill bolt, fill until it starts to leak out so you know it’s full, screw fill bolt back in. Done.
#38
I sucked it up and paid for the 30k service at Arrowhead Lexus (AZ) and I learned a few things. Total came to $655 after $35 service coupon, otherwise it would have been about $690-700
1. With regard to the "Check Differential Fluid" item. I was told that they check the differential fluid by draining it. Once it's drained, they're not going to put the old oil back in, which is why they just change it. Note that the service manual never says when to change the oil, always to just check it.
2. Total parts charges for all items except diff oil was $218 including 2 FOB batteries at $8ea, oil, oil filter, and cabin and engine air filters.
3. Total labor for all items except diff oil was $332.
4. Diff Oil change was about $74, parts and labor, so not a huge portion of the bill like I kind of originally thought.
5. $46 Disposal fee and shop supplies fee.
A final note: While I coul dhave saved money by not going through the dealer, I often sell my vehicles private party, and providing dealer service documentation does seem to help get a better price and make an easier sale.
#39
Received 1,737 Likes
If you really want to check diff. fluid, remove the fill plug, observe a small amount drip out, and replace the fill plug.
If nothing comes out, the fluid is low, top it up or change it (assuming you've confirmed there is no leak)...if it does come out and it's dirty, change it.
There is no where on this planet that checking diff. fluid involves draining it.
Having said that, what they charged you to "check" it seems to be below market value. The diff. fluid is kinda pricey, so it doesn't leave much room for labor in $74.
Although, $332 for labor on the rest of the items seems a little high as basically they did an oil change, 2 filters, 2 batteries, and checked the brakes.
My best guess is that the service advisor did a little creative accounting with the labor rate for the diff. fluid change and the rest of the service.
30K Miles is still a good time to change diff. fluid anyways, so all in all the vehicle did get the service it needed.
It would just be nice if they were straight forward about the servicing...that way there's no second guessing their integrity.
#40
At the end of the day if finances aren’t an issue, go to the dealer. If you understand you can save thousands and thousands by NOT going to the dealer and that money is important to you, I would recommend that you find a good, honest, reliable mechanic to do the majority of its servicing.
And also do your own research, learn a bit about your car that way you know when your being taken for a ride.
google search mechanics in your city, find a highly rated and thoroughly reviewed establishment THAT IS BUSY. If they aren’t busy they aren’t good. I like a mechanic that says he can’t see me for a week, that tells me he has a ton of people bringing cars to him which usually is a guarantee their good.
Once you find a good, honest & reliable mechanic hold on to him until he retires.
I personally would never let the dealer do engine or cabin filter, batteries, oil change, diff change when I can do them myself or have a independent mechanic do it for a fraction of the price.
