RR Racing vs FIGS LCA NVH/Squeaking
Old 01-30-20, 09:37 AM
dteskmo
dteskmo's Avatar
Originally Posted by s3v3n
Guys, are you 100% sure the squeak is coming from the USRS bushing and not from other components getting stressed out?
Absolutely sure. Once I replaced the USRS with FIGS, the squeak went away.
Old 01-30-20, 09:43 AM
s3v3n
s3v3n's Avatar
That's the logical explanation, but it could the stressed part that was squeaking is now not stressed anymore upon removing the USRS?
Just to share my experience, I never had the squeaking and the NVH(maybe related) issue when I installed USRS. It just felt that other components are stressed due from hardness of the bushing.
Long story short, I went back to GSF/RCF bushing. It's really not designed for street / daily driving based on my preference.
Old 01-30-20, 09:56 AM
flowrider
flowrider's Avatar
Received 1,951 Likes on 1,374 Posts
I had the USRS bushings in my ISF for over 4 years when I sold the car last July. When I installed them I used the hard to find grease specified by and supplied by RRR. They never made any noise for me. And YES, I luved them. A GREAT addition IMHO
Lou
Old 01-30-20, 12:55 PM
nkseto
nkseto's Avatar
Thanks all - just to reiterate... the squeaking only comes from bumps in the road when the temperature is below 50 degrees!
Where can I find this grease and where do I apply it on the bushings? Could someone show me a diagram? Also, would I need to remove the bushings or can I do this cosmetically?
Old 01-30-20, 05:46 PM
sunamer
sunamer's Avatar
figs and usrs are pretty much the same - they are very solid with not a lot of give (virtually none) “bushings”. So, the argument that usrs stressed other components “downstream” while figs do not, does not really hold water.
Old 01-30-20, 07:01 PM
Msumiu72
Msumiu72's Avatar
Look into a nano technology coating for the busing that will protect it from hot/cold temperatures.
Old 01-31-20, 09:03 AM
sunamer
sunamer's Avatar
A video on how to get rid of squeaking in poly bushings
The following 3 users liked this post by sunamer:
dteskmo (01-31-20), krill (10-10-23), s3v3n (01-31-20)
Old 01-31-20, 09:24 AM
dteskmo
dteskmo's Avatar
Thumbs up
https://youtu.be/UbgEvh-rSl4
Interesting concept. If I ever have to disassemble and relube my FIGS bushings I will definitely try the teflon tape. Thanks for sharing this!
Old 01-31-20, 12:13 PM
sunamer
sunamer's Avatar
Disclaimer: I do not know if the method actually works. I am trying to decide if I wanna go with RR or figs route and needed a remedy for the problem of squeaking poly bushings. So, when searching, I came across the video and posted it.
Old 01-31-20, 12:24 PM
s3v3n
s3v3n's Avatar
Before you go RR or FIGS, bottom line consider this: If you are going to track your car, do it, you need it. But if not and just for the sake of experience, then you are golden with just RCF/GSF bushings(this is considered a must upgrade to prevent the inner tire wear).
Old 01-31-20, 12:31 PM
sunamer
sunamer's Avatar
I would like to have a bit less vague steering feel and ideally get rid of that wandering feel. Also, some people here who tried RCF LCA bushings, said, they still experience inner side tire wear..
Old 01-31-20, 12:54 PM
sunamer
sunamer's Avatar
Very interesting. RR Racing sells lubricant for their USRS that contains teflon.
flowrider (01-31-20)
Old 01-31-20, 01:04 PM
flowrider
flowrider's Avatar
^^^^Yep, That's the stuff I used
Lou
Old 02-08-20, 12:25 PM
nkseto
nkseto's Avatar
Lou
Would I need to remove the bushings to apply? Or can I just jack the car up and apply to the exterior?
Old 02-08-20, 02:54 PM
s3v3n
s3v3n's Avatar
Bushings needs to be removed for re-lubrication.
Quick Reply: RR Racing vs FIGS LCA NVH/Squeaking
