RR Racing vs FIGS LCA NVH/Squeaking
Hi All - I've had the RR Racing USRS on my car for about 3 years now. Love everything about the improvements in handling, braking and tire wear, but once the temperature drops below the lower 50s the bushings make a loud, rubbery squeak over every bump and imperfection in the road. Lubricating the bushings is not a permanent fix - the squeaking comes back after a few weeks or so.
Does anyone know if the FIGS LCA bushings have the same squeaking problem in colder weather? If this is not the case, I'm tempted to swap my RR Racing for the FIGS 90 durometer bushings, assuming they are comparable in benefits and NVH? An alternative would be to grab a pair of the GSF/RCF bushings but I'm not sure if the performance benefits/tire wear issues are comparable to RR Racing/FIGS.
shenry500 (02-04-21)
I don't think you switching to a different durometer bushing would fix that, from what I remember, those bushings are made of polyurethane as opposed to Leuxs OEM which is rubber. I didn't want to deal with lubricating the bushings so I just got the RCF/GSF ones.
I have the FIGS, installed last spring, and have had no squeak issues on bumps this winter, and I go over several speed bumps in a parking lot every day.
The only issue I have is a ‘squeal’ on slow sharp turns, like pulling into a parking stall, or backing out of my driveway. Have not had a chance to regrease or otherwise lube them. And it started long before the weather got cold.
Hey there man, I also have the RR Racing USRS and ever since winter hit in california they have been squeaking like crazy. I have retorqued all the spindle nuts to 110 and added loctite, but it hasn't seemed to help. For now I am just living with it. If you have any recommendations please let me know.
My RR USRS have been squeaking for some time now as well. Whenever it is dry cold temperature, they squeak loudly. RR inspected and told me mine was since I have the AWD it was the lower control arm but idk. I have learned to live with it or turn up the volume on the radio. Any poly material will harden in the cold and cause it to squeak. All depends on where you live.
I don’t listen for the squeal, but it happens pretty much all the time when I back out of the driveway and then turn sharp when going forward to not hit the curb. Not sure I’ve heard it on a slow sharp right turn, just left turns. Suspect the right bushing needs to be regreased. It was the first one I installed and maybe didn’t grease it well enough.
How does the car feel on the USRS vs the FIGS? I know the USRS definitely makes the wheel a little tighter.
I've had the USRS on the car driving for about a week now. No squeaks yet, only positive things to say. It really is an awesome upgrade. Steering is heavier(Which I desire), Car feels more solid when decelerating from high speeds(No more dynamic alignment change), and car feels overall stiffer. I really have no complaints so far. Going to be checking out the torque specs again this weekend.
I found they perform pretty similar to each other. Perhaps the steering was a little tighter with the USRS, but the extra NVH and squeeks made it a worse choice for me. We have very cold winters here, so the squeeks were much worse in the winter, yet the FIGS have only squeeked three times on -30 degree or colder days and never when the temp is higher than that.
Former Sponsor
Maybe the lube is frozen? (is that possible?). You did lube the red rubber areas with the very special clear Poly Lube right? (Do not lube around the bolt, that does nothing).
FIGS is the same concept with a free moving bushings. If you want guaranteed no-noise/no-lube .. then use the Lexus RCF Bushings.
