Warning door open tone after car off?
When I park in my garage, often need to check if I have the car positioned correctly before I turn the engine off. The sequence of steps is:
- Pull into garage
- Put car in park
- open drivers door to check positioning of car
- If car position OK, with door still open, turn off ignition
At this point the car gives me a warning tone. I'm not sure why. If I close the door and then turn the car off, no warning tone. Any ideas?
- Pull into garage
- Put car in park
Received 1,738 Likes
If there is a warning chime of some kind then you should see some sort of text/light on the dash.
Do you see any lights/messages on the instrument cluster?
drives cars
Sometimes if I shut the car off, it gets confused and says "Shift into P when parked" even if I am already in P. I think there's a slight delay for the car to catch-up and figure out what gear it's in. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Not sure if that's the same thing you are seeing, but it's the only warning chime I remember getting.
Thsts completely normal in this car. Its letting you know so you dont leave a car door open and walk away. Of course in this case it's the driver door, which you are obviously aware of. But if a passenger door was ajar you would want to kno . Should show up on the dash too. You can probably turn that off. I turned off my headlight on warning beep and seatbelts warning beep.
Same with windows or moonroof, but no beep/chime, just tells you on the dash your leaving your car with something open.
drives cars
Hi
Im looking to get the chimes on my 02 GS 300 to work, I have no chimes for anything, if I could them to work, I be happy lol.
Happy New Year to all!!!
