Axel removal for Frs diff swap on 3is
Old 02-23-20 | 03:48 AM
i250s's Avatar
i250s
Default Axel removal for Frs diff swap on 3is
Hi I’m planning on swapping my diff for the lsd from the Frs and I had a few questions about it before I start and was hoping you guys can help ! So I was wondering if I MUST remove the axel from the hub in order to remove the other end from the oem diff.. and if I do, will I just be removing the hub completely then unbolting the axel from the hub ? Or would I be able to leave the hub and the axel together and just lower the diff then the other end of the axel will slide out of the diff once lowered enough ? Sorry if I might sound confusing I’m kinda new to working on my car and everything haha so any tips and tricks would help too thanks !!
Old 07-24-21 | 11:31 PM
Deklan's Avatar
Deklan
Any luck on your question? Looking to do the same diff swap from a 2013 frs to a 2015 IS250 and am trying to figure out the axles on the Lexus. Thanks
Old 07-25-21 | 08:15 AM
Rudiculous's Avatar
Rudiculous
Try in here:
https://www.clublexus.com/forums/is-...-15-is250.html
cheez
Performance & Maintenance
21
02-25-12 11:45 AM
Sc3001jzTT
07-29-10 05:35 PM
RMMGS4
10-25-07 03:35 PM
VSsc400
19
07-08-04 09:02 AM
