I chose AWD because I live in a climate where it’s a blizzard 5 months of the year, also I could only afford 2014/2015 models which come with no LSD (limited slip differential) meaning RWD models for those years are essentially 1 wheel drive cars.
No, with traction/stability control, both rears are effectively driven. It works.
The RWD will most certainly have better handling. I would go with that personally.
MotorTrend tested both and said...
“When it comes to how the car drives, the difference is less obvious. You might expect the AWD would change the handling characteristics, but it isn't noticeable. The steering is no heavier and no less communicative, and there's no hint of torque steer. An advantage of the full-time all-wheel drive system is you'll never feel the front axle connecting and disconnecting, which means it won't upset handling”
I guess the RWD versus AWD argument, in terms of handling, is mostly on-paper. AWD cars weigh more, so they would be lazier, in theory. "In theory" is the key part here. I think it's not a huge difference. For me the RWD car would still be the way to go however. I find it just feels a little more eager both in handling and acceleration.
