AWD trans v. RWD trans
So as you all know my 2015 IS350 base AWD was totaled when a young girl rear ended me going about 55 on the freeway while I was at a stop. I am looking at another 3rd gen IS350. I loved me AWD, but I am intrigued by the 8 speed transmission of the RWD models vs. the 6 speed transmission of the AWD models. Anyone have experience driving both? Thoughts? I’m not in any rush so I can be picky and choosy. I just want to make the right decision. Would love to hear feedback. Thanks.
I drove both but they were both RWD before Lexus switched over to the 8 speed. (4GS vs. 3IS) IMO, it comes down to what you're looking for because I felt the 8 speed was more decisive in its gear changes. The 6 speed would hold onto a gear a little longer giving me the feeling of a little more aggressive drive whereas the 8 speed always sought to maintain a low RPM. I would honestly suggest hitting up a local CarMax and driving both in normal and sport mode. Also, AWD sits a little higher than RWD so you may also want to take a look at the aesthetics unless of course you're going to adjust the adjust the height with aftermarket parts then nvm.
The RWD 8 speed will probably be lighter and have different weight distribution vs the 6 speed AWD, it'll probably handle better as well. You also will not have a hump in your driver's side footwell, so you have a bit more space. I would suspect the fuel economy should be better too.
Not seeing much reason for AWD if you're in Tennessee. Even up here in the Toronto area, I've driven in most major snowfalls this year and had no issues getting around with a good set of winters on.
Weight distribution, ground clearance are so close it’s not worth mentioning. Also based on several magazine reviews I’ve read on the cars the AWD model doesn’t handle any differently, that’s something they mention as surprising.
I chose AWD because I live in a climate where it’s a blizzard 5 months of the year, also I could only afford 2014/2015 models which come with no LSD (limited slip differential) meaning RWD models for those years are essentially 1 wheel drive cars.
I believe 2018+ Fsport models get a LSD. If I lived somewhere with less snow and I could have afforded the RWD model with LSD I would of chosen that, but I figured I’d rather have 2 wheels with power to them vs 1.
As a Canadian driver I won't go back to RWD as much as I like it unless it is a secondary car.
I've really come appreciate the AWD when roads are not cleared since I know I won't get stuck even with winters that have low tread, that was an issue with my old 2010 RWD even with good winters but for down south not so much an issue.
drives cars
I will say, the RWD model has a slightly more agile feel than AWD. Could have been placebo, but I was impressed how different it felt compared with my IS 300 AWD. Again I'd say drive them both, preferably back-to-back.
There are some other things to consider with the RWD model. It has the F Sport brake pads, which are high-friction and will wear out faster. However, they also have better fade resistance in theory. Personally, I like the standard pads (which the AWD model has) just fine. They feel the same in normal driving.
drives cars
There's a whole thread about this topic on the forums, so I'd defer to it. I'm almost certain that the F Sport RWD models get Textar pads, whereas AWD gets Advics front pads.
I live in Connecticut, we get real snow, but I went with the RWD model (2015 IS350 F-sport). The 8spd trans shifts quicker than the 6spd (especially in S+ mode). As to tire spin on acceleration, you just have to calibrate your foot instead of planting it and going, but if that is your method the traction control is actually pretty good, it doesn't completely neuter the car when it activates.
The AWD cars I test drove had more driveline noise and the shifts weren't as smooth.
As to handling, they feel eerily similar, I didn't push the AWD to the limits of grip during my test drive, but did attack some corners aggressively and was impressed.
As to fuel economy, take a walk over the fuelly and see what people are averaging, I think it will be a small difference on average, with the RWD model being more efficient.
I think you'll be happy either way, it really depends on what your preference is with drive trains; I prefer the ability to oversteer on demand.
arentz07 (03-03-20)
arentz07 (03-03-20)
I saw this thread where you say the fsport rwd rotors are “different”. I thought the difference was the diameter, what is it?
https://www.clublexus.com/forums/sus...rt-brakes.html
