Factory ML Amp Sub Signal
Hi,
does anyone have pictures of diagrams showing where I tap into the factory subwoofers signal? I am going to be installing a aftermarket subwoofer, but I can’t seem to figure out which cable to tap into for the subwoofer signal.
also, where do I connect the remote turn on for the amp?
Did you solve your own problem? I'm installing an amp/sub as well, do you have any info that you found to share? I found this helpful thread:
https://www.clublexus.com/forums/is-...ap-ml-amp.html
qha_vn
07-21-09 04:14 AM
