2015 is350 AC compressor clutch not engaging
2nd gear
l have is350 f 2015 series1 and the ac compressor is not engaging when its in cooling mode. l checked if the clutch moves by applying 12 volte dc using power probe and it did engage. l am unable to find the ac relay to check if it burned out. does any one knows where it is located? l don't have the manual to check it. l already checked the two fuse box but couldn't find ac relay other than 7.5 amp fuse and the fuse is ok.
Any help would be much appreciated.
2nd gear
Hi buddy, l sold my car long time ago lol but l remember what the issue was. The clutch was not engaging because it was low on gas (refrigerant r134a) when l hooked the refrigeration gauge hi side was low. If l remember correctly l jumped the low pressure cut out and the compressor engaged, that's when l knew it was low on gas. I pressurized with nitrogen and l was unable to find leak, l vacuumed the system and put r134a refrigerant as per manufacturer volume. And worked well for 2 summers then sold it. I am a refrigeration mechanic but l am sure you can do it by watching on YouTube. It's not that hard. Hope that answered your question.
