NEED 12v POWER in my 3is... what to do with no CIG jack?? 12v inverter
misleading title .... sorry.
have any of you guys installed a power inverter? WITHOUT using cig outlet. would like a permanent solution, without something coming out of my console.
interested in hardline. something permanent
something like this ...
if so ... what solutions have you done??
thanks!
thanks!
Received 1,738 Likes
What about the Power Outlet in the center console? Are you able to use that instead?
Rhydg1 (05-19-20)
I've been using this inverter in my car the past couple of weeks for work stuff. It works well to power normal household 110-240 VAC plugs.
https://www.homedepot.com/p/BLACK-DE...E&gclsrc=aw.ds
i dont want to use any outlets IN the console.
want to mount the invertor somewhere permanent so would like wires somewhat hidden too
Jazzrock (05-20-20)
It still brings us back to the Power Outlet however...as the wires that feed the Power Outlet are 12V and Ground.
If you don't want to plug into the Power Outlet, then tap into the wires that feed the Power Outlet. That way the circuit will still be fused (10A) in the event whatever you plug into the Inverter draws over amperage.
Maybe if we knew what you wanted to plug into the Inverter it might help to give a better option as to a solution.
TLeexus (05-21-20)
