Help! Work Meister S1 3P
About to order a set of Work Meister S1 3P but not sure what specs would fit without issues on a 2017 IS F Sport. I am on an Airlift 3P air suspension.
Was told these specs would work but want second opinions
19x9.5 +12 R-Disk for front
19x10.5 +36 O-Disk for back (would require camber and toe arms)
Received 1,736 Likes
Wow...that's definitely some specs you have there for the wheels.
I guess a couple questions are, do you want the wheels to fit, or do you want to make the wheels fit? Definitely some large wheels you are trying to get on the car.
If you want the wheels to just bolt on and have little to no issues, then I suggest:
19x9.5 +36
19x10.5 +48
Those specs will be basically bolt the wheels on and drive.
There are several members on air, so hopefully they will chime in.
19x9.5 +36
19x10.5 +48
Just a couple observations on the pic...
1. The tires are so undersized and stretched for the rims that they are on it's no longer safe
2. They likely have camber arms at all 4 corners for the rims to clear when aired out
3. This would be an example of making the car fit the rims, not the rims fitting the car
Here's another member that had an aggressive fitment, that was not even as aggressive as the one you posted, and ultimately replaced the wheels for ones that actually fit the vehicle: https://www.clublexus.com/forums/bui...l#post10779275
