New wireless CarPlay/AndroidAuto for oem 10.25 screen
#151
just noticed the vid from peasodos from another post. https://youtu.be/UMan4CNy7kw
I'm thinking that the reason why joystick control is weird is bc depending on the what OEM screen it might be on in the background, your limited by the range of joystick movements since in OEM it tends to "snap" to the next choice on the screen. So when in Carplay, you can be trying to go move a certain direction while the background OEM screen is limited.
#152
Well I just spent last 2 hrs taking the trims apart and everything was connected but it doesn’t work. My joystick doesn’t work after I hooked everything up so not sure if CarPlay even works. I got the right toggle switches. In the manual I was told I don’t need to connect this cable if I have joystick connector. Does anyone have this connected?
this wasn’t easy task it looks easier on video but when you actually do it yourself it’s very exhausting especially when it doesn’t work. Now I need to text those guy in China for tech support.
#153
I tried didn't work, I wasn't sure if I need to connect the small connector to the box there are two jacks, I connected to each one didn't work. But I didn't play around with Green and Grey wire on this cable did you have to do anything? Is yours Carlinkit? How did you connect the screen split cable?
#154
I havent received it yet but it says that cable has to plug into the factory cable for the screen and if you have the ****, you plug the green ones in and plug the adapter into the main screen. Also if you have the switches that are numbered, change them so 3,4,5 are all on
#155
What is your screen size, joystick and you bought Carlinkit?
#156
#157
So my kit just came today. Question for those with the 10.25 screen for the CAN connectors with the split screen. Did you guys do anything with them in terms of unplugging them? Dojoman's picture got me confused if I need to do anything with them or not.
#160
i don’t have the unit in front of me yet but some of the instructions on the pdf are vague.
i ordered top road version for OEM 10.3 inch remote touch with Factory NAV.
#164
This might sound like a dumb question, but because I have never installed the workaround for displaying video when car is on the move, will the carplay and/or any video input display while car is on the move? Is it necessary to install the workaround together with this box? thx
#165
zhifan1 (06-27-20)
