New wireless CarPlay/AndroidAuto for oem 10.25 screen
Old 06-27-20, 09:25 AM
  #166
zhifan1
zhifan1's Avatar
Hopefully IOS 14 plays nice with this box.. gonna get me one...
Old 06-27-20, 10:00 AM
  #167
mazdamx594
mazdamx594's Avatar
I actually asked the seller about that. Carlinkit has a website with firmware updates when iOS changes.
Old 06-27-20, 12:23 PM
  #168
dojoman
dojoman's Avatar
Is this it?
http://www.carlinkit.com/softdown
Old 06-27-20, 01:06 PM
  #169
kobrah
kobrah's Avatar
Originally Posted by NikNikNik
There’s almost a perfect spot for it behind the glove box, and it’s only 5 screws and 3 bolts to remove the glove box
thanks, I’m gonna go that route.
can you please take a look at the one I bought from eBay. Let me know if it looks the same as your box
https://www.ebay.com/itm/362985357148
Old 06-27-20, 01:27 PM
  #170
NikNikNik
NikNikNik's Avatar
Yup that’s the one
Old 06-27-20, 02:07 PM
  #171
mazdamx594
mazdamx594's Avatar
Originally Posted by dojoman
I think so. I viewed it on my computer that converted the text to English. My iPhone doesn’t convert.
Old 06-27-20, 04:30 PM
  #172
kobrah
kobrah's Avatar
Yup that’s the one
ouuuweeee
thanks again man. Are you experiencing any of the control issues with the joystick(remote control) that dojo is experiencing ?
like any OEM infotainment options being selected in the background when using CarPlay?
Old 06-28-20, 09:24 AM
  #173
NikNikNik
NikNikNik's Avatar
Nope everything works perfect for me
Jazzrock (06-28-20)
Old 06-29-20, 08:24 AM
  #174
ejisfun
ejisfun's Avatar
I just installed my carlinkit box in my 2016 RX with nav and my joystick (along with the map, menu, back buttons) doesn't work at all, even in OEM menus. If I uninstall the box everything works fine again. Did anyone else have this issue? Is it a problem with the wire harness?
Old 06-29-20, 08:38 AM
  #175
mazdamx594
mazdamx594's Avatar
This is most likely a settings issue. Check the "dip switches" on the side of the carplay box, there should be a sticker on the box showing you the correct position of the switches, or if not, it should be in the directions.
kobrah (06-29-20)
Old 06-29-20, 08:53 AM
  #176
dojoman
dojoman's Avatar
I had the same issue for my 2014 IS with joystick and Nav. Joystick works if I unplugged everything, I tried to set all toggle switches combination none of them worked for me. Does your harness have black connectors with labeled "High new split screen and old no split screen" try to reverse these connectors to see if joystick works. My joystick works if I swap but then it was controlling both systems at same time.
Old 06-29-20, 09:20 AM
  #177
Javan96
Javan96's Avatar
It could be the cable is connected incorrectly, I noticed that the connectors are the same size and fit, mine was connected incorrectly at first and I couldn't get any audio.
Old 06-29-20, 09:29 AM
  #178
kobrah
kobrah's Avatar
Just got in
Old 06-29-20, 09:38 AM
  #179
kobrah
kobrah's Avatar
just got my road top unit. Setup is same as yours.
can you please verify if preconfigured cabling for both looks correct ?
Old 06-29-20, 10:00 AM
  #180
ejisfun
ejisfun's Avatar
Ah the CAN control cable had come disconnected and I didn't realize. My joystick works now...but there's a new problem.
When I hold the menu button to switch into CarPlay, I hear the carlinkit box "click" and my screen freezes. It seems like it's switching to CarPlay but just not showing it on the screen. If I hold the menu button again, the screen unfreezes and works as normal again.
Quick Reply: New wireless CarPlay/AndroidAuto for oem 10.25 screen
