New wireless CarPlay/AndroidAuto for oem 10.25 screen
sml7781 (09-18-20)
#409
Guys, help me, I just tried to connect Carlik to my car, but my joystick does not work. It might take a while for it to work, I waited about a minute, but neither the joystick nor the buttons worked. Perhaps I am connecting something wrong?
I have IS 350 2015 with navigation and joystick
SET
2 This cable is used to connect to the joystick, but when you connect it, it stops working, the cable says that it is for *****, probably the wrong cable was sent
3 Did you use this wire in your setup? The instructions say that it is not needed for cars with a joystick
box
box2
head
4 How should these wires be connected, do you need to put a loop?
6 Did you use this wire? The wire says that it is for **** control
My car
7 My connection option
1)Maybe I was just waiting for the joystick to work?
2)Have you connected anything other than the blue cable to the screen?
3) I used 1 installation option from the instructions
4) I turned on 2345 switches
After several hours in the car, I got a working joystick, but only on the OEM screen, I connected a jumper.
In the package, the jumper was connected to the cable that connects to the joystick. As I wrote earlier, my joystick cable is marked with a ****. I took the jumper out of the cable and plugged it into the cable that goes from the head unit to the carLK box. After that, my joystick started working on the OEM screen, but still does not work on the CarLK screen, I connect the phone and see the carplay screen, but I can not do anything.
The instructions say that first you need to select the AUX source. after that press the menu button for 4 seconds it switches the screen, but I have empty in the AUX menu and pressing the menu button does not change anything
SET
box
box2
head
My car
#410
Finally, I managed to start it, working with a joystick is a pain. but I am quite controlled by Siri. The only thing I want to update is software, but I need a password, I will ask the seller.
For the joystick to work, the first toggle switch must be turned on. Now I have 1-2-5 turned on, I did not see the difference between 1-2-3-4-5
#411
You can follow Beatsonic install of their unit. The boxes are different but should be very similar but I would not remove glove box you can tuck in the unit behind the radio.
https://youtu.be/xW3Sp1KRbhs
I worked with them to get this on the Non-Nav IS, i worked with Beatsonic and thier developer to make sure this was all good and running and ran tests to give them LOG data to make sure it was perfect i have been running with this beatsonic one over a year without a problem. it sounds very close to my OEM BT connection setting so I like it, I also use an App with equalizers to help out as well to go more custom on sound and using a its own Audio Engine(Helped a lot). I will be adding a AAWireless Box module to this to have a wireless Android Auto Setup with my Pixel 5; the only issue i have come across was with Calls, when taking a call with this connected I heard some people hear me chopped up. So i just get off AA to my OEM screen and its fine. With the AAWireless Box module that should fix that since it will be hooked up through a Wifi GHz and it will act as a the UX200T android auto.
But BeatsonicUsa has been amazing in support and i'm glad I can tell the developers exactly what's is happening and how to get to it so they can fix the code, as a software engineer myself I have even told them I can help out if need be with debugging to make this product perfect (which so far it is other than the call bug, which they said can be fixed with a external mic but for im fine with the way i do it for now till I get the AAWireless Box module )
Ay questions can reach me on my insta @dev_3is, happy to answer any questions on the Beatsonic one
#412
Just wondering, is there a new software for the roadtop carplay/AA module? Mine is working fine, but just wondering whether there is a newer one, that MCU verion file, thanks..
zhifan1 (12-17-20)
#414
#415
Looking over this thread here, 11 pages is a lot to parse.
Can anyone give me a TL;DR for 2018 IS 350 F-Sport AWD Navi+Mark Levinson, does this work fairly seamlessly? Seem there are joystick issues, camera issues, etc... Or perhaps new firmware has solved all that?
I'm considering installing this. Wouldn't be my first time installing CarPlay, or a new head unit for that matter.
#416
iPhone X, wireless carplay keeps rebooting
Hey all! My roadtop unit has been amazing. But today it stopped working for my iPhone X. If I use wireless carplay it literally keeps rebooting the roadtop unit again and again. And when I use wired, it reboots once and doesn't recognize my phone until I reconnect . Then it reboots and stops recognizing.
This only happens with my iPhone X . I tried other i phones and it works just fine.
I even updated my software to latest iOS. Any one seen this happen before?
#417
#418
Lexion unit and larger screen Installed today. Spent about 20 minutes with one of the managers of the shop. We both figured it out together. Works great. Sound is
excellent. Steering wheel buttons work fine. The tech returned and said to hold Menu to return to the Lexus menu, which saved a few
steps. I'll play with it more tomorrow. The larger screen is amazing! A CL member is coming here tomorrow to check it out. Three thumbs up!
#419
I have front camera interface from Beatsonic where it's hooked up to OEM screen with blue connector. Not sure I can keep it if I install Wireless Carplay unit, I basically need to daisy chain both of these units together. Does any of you guys also have Beatsonic front camera switch installed with Carplay?
topic a bit unearthed, however, I wanted to ask if you managed to connect carplay and front beatsonic camera at the same time?
#420
