Help choosing offset
Hello everyone, I couldn't find a "will it fit" thread for the 3IS so I'm asking here for help regarding which wheel offset I need without using wheels spacers.
My car (2015 IS250 F Sport AWD) is completely stock at the moment but after I get wheels I'm considering RSR Downs or Super Downs.
I plan on staying with the oem spec tire size. Yokohama Apex 225/40-18 & 255/35-18
I also read that incorrect wheel sizes can cause differential problems, so I hope I could get help to choose what I need to keep my car's reliability.
I plan to purchase a set of TE37 Sagas but need help deciding which offset to go with.
Here is the available offset from the website I have been looking at.
Front, 18x9 +35 or +45
Rear, 18x9.5 +22, +30, +38 or +45
I prefer a staggered setup with a concave look but whatever works best is good enough for me.
All help is appreciated, thank you everyone
Received 1,738 Likes
Based on the specs you provided, this is your choice for a staggered setup, and using the OEM tire sizes:
18x9 +35 with 225/40/18
18x9.5 +38 with 255/35/18
You could go larger if you like...here is my setup on basically the same car as yours, mine is a 2014:
18x8.5 +35 235/40/18
18x9.5 +38 265/35/18
I'm using Firestone Firehawk Indy 500 tires...which are a narrow fitting tire, so it clears the rear no problem, and I'm on RSR Downs.
CA53W (07-03-20)
Personally i want to stay at 18", but I'd be willing to go even wider.
What's the maximum width you'd recommend for 18"?
I have 18x10 available in +35
And 18x10.5 in +15 and +24.
If you go with a staggered setup, then front 18x9.5 and rear 18x10 +42...you might be able to squeeze an 18x10.5, but offset and tire size/brand has to be perfect at that point.
It looks like I'll be going with
I'll send photos after I have them installed.
