Audio system connection
Hi there
I have an IS with non-mark levinson system “pioneer”. The amplifier get wet damaged. I tried to fix it but I found no way. Now I need it to be replaced but it is too expensive and I have an aftermarket amplifier do you think there is a chance to connect it to the original radio?! If anyone of you knows the pins order and connection please let me know. 💔💔
thank you for your time
Received 1,737 Likes
What year/model of IS do you have? I may be able to provide the North American wire diagram, and hopefully it's the same as yours.
Assuming you have the same wiring as we do, the two attached docs should give you all the information you need to wire up the aftermarket Amp.
