Maintenance - 80K is250 2014
I made a question like this before on a 60k car. People said tranny fluid and spark plug. Not so sure about the plugs I did some research and found they are iridium correct me if I’m wrong but they are supposed to last till 100k. Tranny you should change the fluid for long life.
Spark plugs, transmission fluid drain n refill, differential(s). You could probably do the serpentine belt also.
make sure your engine and cabin air filters are good.
