looks good but i've never seen a set sold for less than $2K.. not worth IMO
There is a replica out there of the GSF wheels...one forum member had them before he got rid of his IS. Likely they are less expensive and look the same.
Just put on some OEM GSF rims on my 2014 IS350 F-Sport
235/35/19 | 265/30/19
Stock F-Sport suspension & springs
5MM spacers in the front
IG: Nebula3is
Any rubbing or fitment issues with the GSF wheels? You mentioned 5mm spacers in the front... were these needed to clear the calipers? any rubbing with the 235 and 265 tires? any room to upsize to 245 and 275?
i just got a oem set myself, it rub like a mf on those size wheels. i currently looking into tire sizes myself. i’m thinking his set up won’t rub. the 5mm front space is for clearance of the calipers. Bruh its like 1mm away without it
i ran the replicas on my car a while ago probably back in 2017 when i got it, i ran 225/35-19s up front and 255/30-19s in the rear with no rubbing on RSR downs and i also didn’t use spacers
