Wheel Fitment
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
If this is the wrong area I apologize I wasn't sure the correct area.
I was wondering if someone could help me I have a 2016 Lexus is200t f-sport and was wondering if 18x10.5 +25 offset with a high disc will fit without hitting the oem big brake? I am on air suspension also just so that's out there. I did run 18x10.5 +18 but I had to use a small spacer and am looking to not have to run one on my new set up now.
Thank you ahead of time for your input.
Received 1,735 Likes
Welcome to the forum!
Based on the specs you provided, 18x10.5 +25 won't fit on the front or the rear.
To fit the rear it would need to be a +45.
For the front it's just too wide...no offset with make it fit.
You may want to recheck the specs of the wheels you had before cause a 18x10.5 +18 should have been outside the fender and not need a spacer...unless the spoke design didn't clear the caliper.
Also I'm not sure how you would have ever aired out unless you had fender work done already...or a wide body kit.
Never seen a 3IS with 10.5 on the front...with stock fenders and quarters.
It may help if we knew what rims these were...it seems to be at least a 2 piece if not 3.
