code problem VGRS
code problem VGRS
hello ,
I have a problem with agauge I changed to F sport gauge and after the installation this code VGRS appeared to me and I could not remove it Is there a technical solution to solve this problem ?
Likely you pulled the F-Sport cluster for a 350 and yours is a 200t/250/300. I have not tried, but I think you may have luck removing the code using Techstream, going to the Combination Cluster ECU, and clearing the DTCs
BabyBump12
11-23-11 12:59 PM
