3IS Fuses (Interior and Exterior Fuse Boxes)
After getting frustrated with finding the function of each fuse and having little luck on ClubLexus, I figured I'd make a thread that lists all of the fuses. I expect this first post will be updated as user post the use of a fuse and the the scenario for power.
Fuses size - "Low Profile Mini/Micro"
RL - indicates relay
Interior Fuse Box:
ECU-B (10A) -
DOME (15A) -
AM2 (7.5A) -
J/B-B (10A) -
RADIO (15A) - Fuse for radio. Powered when car is off.
OBD (7.5A) -
SHADE RR (7.5A) - (unsure how it's used if the vehicle doesn't have a rear sunshade)
TRUNK OPN (7.5A) -
WIPER SW-IG (5A) -
ECU-IG NO.2 (10A) -
BKUP LP (7.5A) -
ECU-IG NO.1 (10A) - (why are there several ECU fuses?)
J/B-AM (10A) -
P/W (5A) -
FOG RR (10A) -
A/C (7.5A) -
HAZ (15A) -
STRG LOCK (20A) -
ODS (5A) -
CAPACITOR (10A) -
SMART (5A) -
ECU-ACC (7.5A) -
TAIL (15A) - Fuse for tail lights. Only powered when headlights, parking lights, or AUTO lights are on. (great for powering fog lights)
PANEL (7.5A) -
IG I NO.2 (10A) -
IG I NO.1 (10A) -
TI&TE (20A) -
S/ROOF (20A) - Fuse for sunroof. Powered when car is off.
DOOR DBL/L (15A) -
METER (7.5A) -
A/BAG-IG2 (7.5A) -
IGN NO.1 (7.5A) -
IGN NO.2 (7.5A) -
P/SEAT F/L (30A) -
DOOR F/L (30A) -
P/OUTLET NO.1 (15A) - Fuse for 12Volt socket/Cigarette lighter. Powered when car is off. (does no.1 indicate there was intentions of a second socket for the car?)
DOOR R/L (30A) -
AMP NO.2 (30A) -
AMP NO.1 (30A) -
D/L (30A) -
S/HTR F/L (15A) -
S/HTR F/L (15A) -
P/SEAT F/R (30A) -
IG I NO.3 (10A) -
DOOR F/R (30A) -
DOOR R/R (30A) -
Interior Fuse Box:
ECU-B (10A) -
DOME (15A) -
AM2 (7.5A) -
J/B-B (10A) -
OBD (7.5A) -
TRUNK OPN (7.5A) -
WIPER SW-IG (5A) -
ECU-IG NO.2 (10A) -
BKUP LP (7.5A) -
J/B-AM (10A) -
P/W (5A) -
FOG RR (10A) -
A/C (7.5A) -
HAZ (15A) -
STRG LOCK (20A) -
ODS (5A) -
CAPACITOR (10A) -
SMART (5A) -
ECU-ACC (7.5A) -
PANEL (7.5A) -
IG I NO.2 (10A) -
IG I NO.1 (10A) -
TI&TE (20A) -
DOOR DBL/L (15A) -
METER (7.5A) -
A/BAG-IG2 (7.5A) -
IGN NO.1 (7.5A) -
IGN NO.2 (7.5A) -
P/SEAT F/L (30A) -
DOOR F/L (30A) -
DOOR R/L (30A) -
AMP NO.2 (30A) -
AMP NO.1 (30A) -
D/L (30A) -
S/HTR F/L (15A) -
S/HTR F/L (15A) -
P/SEAT F/R (30A) -
IG I NO.3 (10A) -
DOOR F/R (30A) -
DOOR R/R (30A) -
The following 5 users liked this post by PJSnow:
Engine Bay Driver's Side Fuse Box:
FUSE PULLER - Don't lose these... the aftermarket pullers suck.
EFI NO.2 (10A) -
EFI-MAIN (25A) -
A/F (15A) -
P INJ (10A) -
IG2 (10A) -
IG2-MAIN (20A) -
H-LP RH-LO (15A) -
H-LP LH-LO (15A) -
FAN (RL) -
S-HORN (RL) -
HORN (RL) -
WIPER (RL) -
STRG HTR (RL) -
INJ (RL) -
INT (RL) -
IG1 MAIN (RL) -
EFI MAIN NO.2 (RL) -
DCM (5A) -
ICS (7.5A) -
STOP (5A) -
HORN (15A) -
S-HORN (10A) -
ETCS (10A) -
INJ ( 20A) -
BBC PA (30A) -
ENG-IG NO.1 (10A) -
AVS (20A) -
EPS-IG (5A) -
WIPER (25A) -
ENG-IG NO.2 (5A) -
ALT-IG (5A) -
RADAR-IG ( 5A) -
WASHER (20A) -
A/C W/PMP (7.5A) -
STRG HTR (15A) -
MIR HTR (15A) -
NOISE FILTER (10A) -
IG1-MAIN (40A) -
H-LP CLN (30A) -
FAN NO.1 (50A) -
FAN (80A) -
EFI NO.2 (10A) -
EFI-MAIN (25A) -
A/F (15A) -
P INJ (10A) -
IG2 (10A) -
IG2-MAIN (20A) -
H-LP RH-LO (15A) -
H-LP LH-LO (15A) -
FAN (RL) -
S-HORN (RL) -
HORN (RL) -
WIPER (RL) -
STRG HTR (RL) -
INJ (RL) -
INT (RL) -
IG1 MAIN (RL) -
DCM (5A) -
ICS (7.5A) -
STOP (5A) -
HORN (15A) -
S-HORN (10A) -
ETCS (10A) -
INJ ( 20A) -
BBC PA (30A) -
ENG-IG NO.1 (10A) -
AVS (20A) -
EPS-IG (5A) -
WIPER (25A) -
ENG-IG NO.2 (5A) -
ALT-IG (5A) -
RADAR-IG ( 5A) -
WASHER (20A) -
A/C W/PMP (7.5A) -
STRG HTR (15A) -
MIR HTR (15A) -
IG1-MAIN (40A) -
H-LP CLN (30A) -
FAN NO.1 (50A) -
FAN (80A) -
The following 3 users liked this post by PJSnow:
Engine Bay Passenger's Side Fuse Box:
ENG-AM (120A) -
J/B LH-AM (120A) -
ALT (150A) -
P/I-B (100A) -
ABS NO.2 (50A) -
ST NO.1 (30A) -
ENG-B (50A) -
FAN NO.2 (RL) -
EPS (RL) -
VGRS (40A) -
EPS-B (5A) -
ALT-S (7.5A) -
FUEL PMP (20A) -
ST NO.2 (20A) -
TOWING (30A) -
D/C CUT (30A) -
BBC NO.1 (40A) -
EPS (80A) -
J/B LH-B (80A) -
BBC NO.2 (40A) -
HTR (50A) -
ABS NO.1 (30A) -
PTC HTR 1 (50A) -
FAN NO.2 (50A) -
PTC HTR 2 (50A) -
P/I-AM (80A) -
MPX-B NO.2 (10A) -
MPX-B NO.1 (10A) -
WIPER-S (5A) -
COMB SW (5A) -
ST NO.1 (RL) -
ST NO.2 (RL) -
MIR HTR (RL) -
ENG-AM (120A) -
J/B LH-AM (120A) -
ALT (150A) -
P/I-B (100A) -
ABS NO.2 (50A) -
ST NO.1 (30A) -
ENG-B (50A) -
FAN NO.2 (RL) -
EPS (RL) -
VGRS (40A) -
EPS-B (5A) -
ALT-S (7.5A) -
FUEL PMP (20A) -
ST NO.2 (20A) -
TOWING (30A) -
D/C CUT (30A) -
BBC NO.1 (40A) -
EPS (80A) -
J/B LH-B (80A) -
BBC NO.2 (40A) -
HTR (50A) -
ABS NO.1 (30A) -
PTC HTR 1 (50A) -
FAN NO.2 (50A) -
PTC HTR 2 (50A) -
P/I-AM (80A) -
MPX-B NO.2 (10A) -
MPX-B NO.1 (10A) -
WIPER-S (5A) -
COMB SW (5A) -
ST NO.1 (RL) -
ST NO.2 (RL) -
MIR HTR (RL) -
Engine Bay Driver's Side Relay Box:
RESERVED
RESERVED
Hi, I did connect the ambient light into car door light and connect the host main power of that into TI&TE(20A). It runs good about few minutes then it downs all. How I can fix that ?
In regards to fixing your issue, you may want to reach out to a different thread or start a new one. This thread is intended to document all of the 3IS fuses.
RussellTeo (07-06-24)
really dumb question: where is the interior fuse box for 3IS?
under the steering?
far dumber question:
will dashcam hardwiring void me Lexus warranty is all the fuse got burnt when wrongly install my dashcam?
under the steering?
