pin diagram for OEM Clock
Received 1,738 Likes
There's some variation in the Clock circuit wiring depending on if you have 2014-2018 or a 2019+...and if you have Navi or not.
I'm assuming you have a 2014 with Navi.
Pin 1 (Light green wire) - Battery constant power
Pin 2 (Light blue wire) - ACC power (basically battery voltage when the ACC or IGN are on)
Pin 3 (Green wire) - Illumination Positive (from 7.5A Panel fuse - makes it light up)
Pin 4 - couldn't find anything for this pin - hopefully you do not have a wire here
Pin 5 (White wire) - For 2019+ with Navi - Supposed to go to the radio...not sure why (my guess is CAN+ wire)
Pin 6 (Black wire) - Illumination (Negative) For 2014 - 2018 this goes to the Combination Meter - controls dimming of light (in 2019+ this also goes to Radio, suspect it's the CAN- wire)
Pin 7 (White with Black Stripe) - Ground
GR3Y5H3ART (09-06-20)
yes ty! Sasnuke
IS250DIYER
03-29-20 02:22 PM
LXLUTHR
10-08-18 06:40 PM
Zstuddin
12-03-12 04:47 AM
lexusondubs
102
01-30-10 06:58 PM
