IS300 Fsport - Wheels
Hi All !
Trying to figure out if i can i run these wheels on my is300 fsport. please see below.
Dai Alloy - Auto Bahn 18x8
- Not sure if these will be okay cause of the staggered fit in the back (i think its 18x8.5)
- will the 18x8 still work? (I plan on getting OEM tire fit - F:225/40/18 R:255/35/18)
- it should fit the 5x114.3 bolt pattern
Thanks for the help!
Received 1,738 Likes
Welcome to the forum!
The wheel size and offset are the same as the F Sport front.
According to several online fitment resources they will fit your vehicle.
If you are going to use the same rim front and back, then stick with the same tire size front and back...225/40/18.
It may look a little odd on the rear as the wheel will be set into the wheel well further.
If this is going to be a winter setup, IMO, the appearance doesn't really matter.
You may even consider 17's for winter wheels too.
