LEXUS IS250 2015 evaporator drain hose CLEANING
Hi all,
I have a IS250 2015 in Miami FL
last week both front carpets ,drivers and passenger were really wet
do you know where is located de evaporator drain hose and how to cleaned it?
thanks in advance for all your help
be safe guys
I can't speak specifically to the IS, but on my fathers S197 Mustang there is an issue that develops related to the cowl drain system, where if it's parked outside pine needles/tree debris get in and clog up the drains. You have to remove the cowl & wiper arms to gain access to clean them out.
Does your car live outside?
The drain hose from the evaporator box exits just behind the front passenger wheel.
The actual port on the evaporator box is pretty much dead center of the tranny tunnel under the box...which is behind your dash right about the middle.
Cleaning might be a little tricky...if you have an air compressor, you could try blowing up the hose to try and clear the blockage.
Hopefully some one has other suggestions.
Sasnuke
"The drain hose from the evaporator box exits just behind the front passenger wheel."
do you have a pic? can we unclogged that hose from down the car?
thanks
DJ
thanks,
I already cleaned that
thanks
DJ
thanks,
If you already tried the air blower and no luck, then a flexible wire like mechanics wire could be pushed up the hose to try and clear the blockage also.
If there is water sitting in the box, once the blockage is cleared it should come rushing out.
There is a hose that connects to the box port and brings the discharge towards the passenger wheel.
The right front sunroof drain will also come out somewhere behind the passenger front wheel too. Without my car here I can't go confirm for sure where exactly.
I did have a look at some interior pics of the HVAC box for a 250...there is also a small hose the brings the water from the HVAC box to the blower box, before it's finally discharged.
You may want to check this hose first as it's closer to the actual HVAC box.
In the pic below imagine you are standing in front the passenger headlight looking towards the passenger seat, and you can see through the firewall...In know, that sounds stupid, but that's how they drew the diagram, from the perspective of the side you can't see from inside the car.
The hose is inside the car, the diagram is meant to give you a location relative to where it actually is.
The right side of the pic is closer to the center of the vehicle...the left side of the pic is close to the passenger front door.
If you can easily remove that hose the water might come rushing out there even.
I would suggest from the passenger footwell area.
I'm guessing some trim panels would need to come off under the glovebox and possibly on the passenger side of the center console.
You should be able to poke your head up and under the dash to see the hose.
The drain port on the evaporator box is directly over the tranny, but without a hose to redirect the water, the water would constantly dip on the transmission (no bueno for the tranny).
So count your lucky 3IS stars, that this drain is more accessible.
Curated Content Editor
08-04-20 10:56 AM
Lexfsport1
12-29-17 02:21 PM
