Does the Lexus IS cigarette port draw power when the car is off?
yayeeeet (12-04-20)
Received 1,737 Likes
Confirming also that the Power Outlet in the center console under the armrest is not powered when the vehicle is off.
yayeeeet (12-04-20)
no. But it does in Accessory “key position” or second first Start button press.
I'm trying to figure out a battery drain issue... I have a V1 radar, dash cam both plugged into the console and a Helix amp in the trunk. all should be off when the car is off but no idea why my batteries keep dying???? it's a 2016 so I know the 2014's had an issue like this but the 2016's dont?
I would start with disconnecting both devices completely and charging the battery properly with a charger and then monitor.
If the battery stops dying then reintroduce one of the devices...if the battery is still fine after 4 days, then reintroduce the other. If the battery dies now, then you know it was the second device you reconnected.
Other than that, you could try measuring the draw at the battery, but that can be a little tricky and you need to have a multi meter to do it.
The battery on a 2016 is likely 5 years old at this point, so it could just be the battery.
So, what would happen if you disconnect a battery terminal on the car and leave it for the same time you would normally leave your car? I am wondering if it is a ****ty battery, or whether it is really something that is eating up the juice when it simply sits parked...
To confirm that it is indeed some parasitic draw that is causing it. If the battery manages to lose charge even when being absolutely disconnected, obviously parasitic currents would not be to blame.
You may have a bad ground somewhere.. the wire diagnosing begins..
Smart move on the tender, it won't charge the battery but it'll maintain it somewhat. I do that with all of our vehicles at home, including the two motorcycles in the dining room (lol)
It's a Schumaker SP1286 3 amp charger so it does a pretty good job
I came across almost the same problem recently. Battery would die very quickly after the car was left with just radio and AC, to the point of almost not starting. The car could barely start after sitting for 1-2 days in a garage, or even when left in the parking lot for 20 minutes.
No new devices were added, so I assumed it is the battery that was on its way out, and the cold simply made it more obvious.
But then I decided to clean the battery terminals and the connectors. And after that I drove it for 1-1.5 hrs, and left it in a garage for 3 nights. Tried to start it yesterday and it looks like the problem went away. It started right up without any hesitation or prolonged cranking...
My guess is - bad connection caused the battery to be constantly under-charged.
