RCF/GSF Bushings Deal
Old 12-11-20, 09:30 AM
Tungstn-IS
Tungstn-IS's Avatar
Originally Posted by zhifan1
Is this video the right way to change out the bushing? If it is, it sure helped me made up my mind to not DIY.
Absolutely not! He made that significantly harder than it needs to be. You don't even have to remove the wheels, much less the brakes and other components he disassembled. Its literally 2 bolts and a nut, maybe a pry bar to move the LCA down to get the bushing out.
sunamer (12-25-20)
Old 12-11-20, 10:14 AM
zhifan1
zhifan1's Avatar
Originally Posted by primavera
Zhifan1 Lol that is the craziest way of changing the LCA bushings. I’m surprised he didn’t drop the engine and tranny to do this lmao 😂
https://m.youtube.com/watch?v=RWa3EDMvQXE
LMAO..... this is so much better...
primavera (12-11-20)
Old 12-13-20, 09:17 PM
Flashkid
Flashkid's Avatar
Trying to debate if I should go to the RCF route or RR Racing. Are there any difference in terms of performance? Worth the 4x cost?
Old 12-14-20, 06:42 AM
primavera
primavera's Avatar
The GSF, RCF bushings will give you nice comfortable ride, just a bit firmer the than stock ones. Poly bushings will give you firm performance oriented feel with increased noise and vibrations.throughout the cabin. They also tend to squeak, need to be re-greased and cost significantly more than GSF RCF.
https://www.youtube.com/results?sear...hings+worth+it
zhifan1 (12-15-20)
Old 12-15-20, 06:41 AM
zhifan1
zhifan1's Avatar
Can I assume that this is suitable for RWD 2016 IS200t?
Old 12-15-20, 10:14 AM
Jazzrock
Jazzrock's Avatar
Yes it is.
zhifan1 (12-15-20)
Old 12-25-20, 11:45 AM
Lee350F
Lee350F's Avatar
Thanks for this man! I'd been considering going for RR Racings new LCA bushings that aren't as harsh as the OG's but with the price difference I'll give these a shot first.
Old 12-25-20, 12:16 PM
Teeth
Teeth's Avatar
How are these OEM ones compared to aftermarket ones like RR Racing and Figs?
Old 12-25-20, 12:50 PM
Lee350F
Lee350F's Avatar
From my understanding they're better than stock IS ones and nearly eliminate the tire wear and wandering under harsh conditions while increasing steering feel. Figgs and RR do the same but to a greater extent at the cost of ride comfort and generally higher NVH. Just depends on how much performance you want in exchange for daily drivability/comfort. OEM RC/GS F bushings are the first step away from comfort and towards performance.
Teeth (12-25-20)
Old 12-30-20, 03:50 PM
Oli721
10th Gear
Oli721's Avatar
Hey guys, would these work on AWD versions as well?
Old 12-30-20, 03:57 PM
Napalvr
Napalvr's Avatar
Yes...I have them on my 15 AWD
Oli721 (12-30-20)
Old 01-01-21, 02:15 PM
TOPENDMS
Former Sponsor
TOPENDMS's Avatar
Factory rubber will be maintenance free and is more inline with factory suspension comfort.
RR-Racing requires lube on install and probably every couple years, Poly could cause noise. These will almost completely eliminate movement of the arm at the bushing, and is best if precise handling is the main concern.
anakratis (01-01-21)
Old 01-02-21, 03:37 AM
RRRacing
Sponsor
CL Vendor - Starter
RRRacing's Avatar
Received 1,416 Likes on 648 Posts
The way I look at it is this, the RCF bushings are a bit stiffer than IS350 version, but have all the same issues in terms of their design. They are still too soft for real performance driving. And our USRS system is the ONLY bushing that eliminates both lateral AND axial movement of the control arm.
Now, if you drive around on 400 treadware tire, switching to RCF bushings will improve tire wear. But if you enjoy pushing your car hard and use high performance tires, you’ll have the same issues as RCF owners have with OEM bushings.
BTW, for the record, we recommend AWD users purchase our softer street durometer bushing as it seems to be better suited to the AWD control arms.
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old 05-26-22, 11:06 PM
athanato
athanato's Avatar
Rafi
How often does the RR Racing Street Version Ultimate Steering Response System (USRS) for Lexus (Pair) need to be re-lubed over time?
jfa
11-30-11 04:43 PM
Och
Suspension and Brakes
03-24-10 01:49 PM
Quick Reply: RCF/GSF Bushings Deal
