2014 IS350 Maintenance
Hey guys,
I just bought a 2014 IS350 F Sport with 60k miles, and I'm just wondering what maintenance I should be looking at doing? Looking at doing plugs, trans fluid?, brake fluid, coolant, diff fluid, etc. Thanks in advance, any recommendations will help.
Of course it depends if service has recently been done, but you can find the service schedule at the following link:
Service Guides for all Lexus Models | Lexus Drivers
Here is the 'cliff notes' version for service intervals:
Oil & filter 10k or 1 year, AC filter 10k or 1 year, Key battery 15k or 1.5 years, Brake fluid 30k or 3 years, Air filter 30k or 3 years, Spark plugs 60k or 6 years, Coolant 100k or 10 years then 50k or 5 years thereafter, Transmission fluid Sealed unit - NA, Transfer case Sealed unit - NA
Enjoy!
Enjoy!
Transmission fluid change highly debated but using common sense and understanding there is absolutely NO lifelong fluid especially transmission and it’s not literally a sealed unit...it has a Drain hole, fill hole and overflow flow..if there was such thing as lifetime fluid they’d give you a lifetime warranty on transmission... do a simple drain n refill on transmission for about $150 and possibly prevent needing a new transmission for $5000 down the road. I changed my trans fluid at 50,000km and it was disgusting.
If you service the transmission, use the Toyota oil as it's formulated for that tranny. I know there are good synthetics out there but I hear the Toyota one works the best for this transmission.
All of the above.
Thanks for the information! Do you have to drop the pan/is there a serviceable filter? Do you have any links to any videos/how-to's by chance? I couldn't seem to find any for this exact vehicle. This would be my first time doing a diff fluid change and a trans fluid change of this type, and I just want to make sure I'm doing everything properly.
Maybe you're more ambitious than I am, and maybe you have a lift and room to work, and a place to dump oil, etc., but I sure won't drop a pan and change a filter on a trans. It's not worth it to me to try to duplicate what a transmission shop can do in an hour with their equipment and experience. A guy's got to know his limits--so to speak.
there’s a ton of tutorials on this forum and YouTube.
Received 1,738 Likes
You don't need to drop the pan, and there is no serviceable filter.
The tranny has a strainer, which unless you're rebuilding the tranny, can remain in the tranny indefinitely.
All of the above.
The procedure sounds really complicated, and it’s way more complicated than having a dipstick but it’s actually easy.
1) Make sure car is cold so transmission fluid temp is in between the specified temp range Toyota says verified with an obd2 scan tool or tech stream...
2) undo drain bolt, drain pan..you’ll get around 3 quarts coming out.
3) Refill about 3.5-4 quarts.
4) Turn on car, making sure temp range of trans fluid is within range...have someone put car through Gears
5) undo OVERFLOW bolt and it will start to drain, again verifying transmission fluid temp is still within Toyota specified range, once it’s a steady drip you close the overflow plug.
Car has to be cold, make sure it’s sitting for several hours before you do this if transmission fluid temps reach more than around 50 Celsius you are out of the temp range, fluids expanding to much and your overflow/check level procedure will be inaccurate.
Don’t need to drop pan or change filter.
I watched my mechanic do this from start to finish in 40 minutes...again it sounds complicated, once you get it it’s actually quite simple...you should not pay more than an hour labor plus trans fluid which is cheap if you use Toyota ws fluid.
yep so it’s a “drain and refill” not a flush. Did 1 at 50,000km and another 2 around 75,000km...now I’m going to leave it alone most likely till I get rid of vehicle.
How nasty was the trans fluid? Like dark brown, black? Also, did you do the transfer case service, and the differentials (front and rear)?
Yeah I think I get the part with the overflow, where the fluid gets up to temperature and expands, then the excess overflows. Once the overflow stabilizes, then it's at the right fluid level, no need to figure out exactly how much to add as long as you overfill it a bit on step 3.
