Backup Camera Guidelines Missing
Morning guys,
so my backup camera wasn’t working on my 2015 IS350 F Sport. So I had it replaced by lexus since it was still under warranty. When I got it back yesterday the backup camera guidelines are missing. I’ve read the entire manual and can’t figure out how to get the guidelines back.
when it’s in reverse it’s just the camera view with no buttons or options to click on anything. And under the settings>vehicle> all that is there is maintenance, vehicle customization, and backup camera guidelines. I click on guidelines and select the one I want but when I put it back in reverse they still do not appear. I’ve tried restarting the whole unit as well by holding down the audio power button until reset happens.
Received 1,737 Likes
Chances are when they replaced the camera they didn't complete 1 or more calibrations...they likely bolted the camera in, saw and image on the screen, and figured that was it...that's why you're not seeing the Estimated Course Lines.
The calibration below you can do yourself at home easy...read the NOTICE below first.
If that doesn't work, then refer to the HINT, that calibration has to be done by the dealer.
While it's not impossible for you to do it, it's complicated and will take time and a tool...since the camera is under warranty the dealer should be doing as part of the replacement.
INITIALIZE PARKING ASSIST MONITOR SYSTEM
(a) If estimated course lines are not displayed on the image of the area behind the vehicle, perform the following procedure to correct the steering angle neutral point.
(1) Fully turn the steering wheel to the right and left on flat ground.
NOTICE: Memorizing the steering angle neutral point must be carried out with the engine started. Apply the parking brake, depress the brake pedal, check that the shift lever is in P, and ensure that the vehicle is not moving.
HINT: If estimated course lines are not displayed on the image of the area behind the vehicle with the steering wheel fully turned to the right or left, perform "Steering Angle Setting in Calibration".
So I tried the first thing. It didn’t help. Then I went to the setting steering in calibration and that option doesn’t exist.
the only options I have under calibration are position/Direction and Tire Change
The Steering Angle Setting in Calibration is not a menu option in the vehicle, it's a procedure in the repair manual...Calibration section of the Park Assist Monitor system, under the sub section, Procedure 1.
The dealer will have to do it as it involves a target being placed behind the vehicle at a certain distance in order to calibrate the camera...then you have to go into the Service Menu of the Navi unit in order to complete the calibration.
Just take it back to the dealer if the camera was under warranty...they likely didn't know they needed to calibrate it, hence why you have no Estimated Course Lines.
Perfect thank you! Last question, when I turn the vehicle on it defaults to the full screen navigation. Do you know how to change it to where when I turn on the vehicle it defaults to the radio full screen instead of always having to hit “home” then select the radio section
Note, this is not in the Owners Manual, it's the other book.
Sorry for my miscommunication. When I turn the vehicle on it automatically displays the navigation in full screen. How do I change that to the radio? Page 38 in the navigation manual only shows me how to change the Home Screen.
I just checked my IS to be sure, but the last screen you leave it on when you shut off the vehicle is the one it restarts on.
Try this...Press MENU, then Select SETUP, then GENERAL.
Scroll down until you see AUTO SCREEN CHANGE...confirm it's set to OFF.
Please excuse the dust specs - haven't had a chance to clean the inside in a while.
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/995x434/x18xvw8_5536ea2a74bb166494e43c02550ee9a8361fd577.png)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/984x437/mb2vz4d_7223da2a0ba7e526b7889207d6f7ba1fc4c540be.png)
Please do update when you got this solved.. thank you.
Angeldust
03-17-21 08:08 AM
