of where it is located on the drivers side of the motor and an explanation what I am trying to solve for. I purchased a new pigtail connector and heat-shrink soldering connectors but I really don't want to drive this to work in the morning unless I fix this first. How'd it happen? My dumb **** inadvertently tugged on it by mistake when changing out my sparkplug wires earlier today. The Stealership wants to replace the entire wiring harness ($500) for an additional $600 in labor!!!!!! Wires got pulled out of their connector during a spark plug change. Bought a new pigtail connector. Just no idea what order they go in.
If you're looking from the wire side of the connector, from left to right it's Light Blue, Brown, Black.
I'm surprised you hit the mileage on a 2018 to warrant changing the plugs...I still haven't hit the mileage on my 2014, but I'm still going to change the plugs this Summer.
Thank you sir very much. Anybody have a photo though because I am getting conflicting info and I want to make sure it's not the passenger side sensor which somebody private messaged me with
Sorry for my ignorance but when you state "from the wire side" I am assuming that the locking clip of the pigtail plug is oriented in the "Top" position?
The connector has two sides...the terminal side (which plugs into the sensor)...and the wire side (the side connected to the wire harness).
If you find any of the other 3 sensors, the Light Blue and Brown wires (pins 3 and 2) are in the same position...process of elimination, the Black goes in the last spot.
